Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Transmission Whine??
Old Nov 6, 2007 | 07:08 AM
PostIt's Avatar
Default Transmission Whine??
Does anyones transmission whine at low speeds in first through fourth gear? Maybe Im hearing something that is normal or could somthing really be wrong? It sounds like its whistling... Does anyone else experience this? I thought it might have been due to the close gear ratios in first through fifth any ideas???
Old Nov 6, 2007 | 08:06 AM
Solo2Vtec's Avatar
Default Re: Transmission Whine?? (PostIt)
I noticed the same thing on my car recently.
Old Nov 6, 2007 | 09:37 AM
PostIt's Avatar
Default Re: Transmission Whine?? (Solo2Vtec)
Its weird right it doesnt seem normal...
Old Nov 6, 2007 | 09:44 AM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PostIt &raquo;</TD></TR><TR><TD CLASS="quote">Its weird right it doesnt seem normal...</TD></TR></TABLE>
Seems normal to me.
Old Nov 6, 2007 | 09:54 AM
fandirabbani08's Avatar
yea, but i dont think its the transmission thats making the noise. i think its just part of the engine sound, there is a slight whistle to it.
Old Nov 6, 2007 | 10:05 AM
PostIt's Avatar
Default Re: Transmission Whine?? (Tokyosmash!)
No whining noise seems normal to me, especially whne its coming from something as sensitive as the trans...
Old Nov 6, 2007 | 10:24 AM
killyourscene's Avatar
i had it too with the stock air box. i think it make be the stock intake???
Old Nov 6, 2007 | 11:04 AM
PostIt's Avatar
Default Re: Transmission Whine?? (killyourscene)
Its a whine, something mechanical it gets louder and you go faster, almost like the whine of a supercharger just quieter, its annoying as hell...
Old Nov 6, 2007 | 05:08 PM
Tickle-shits
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PostIt &raquo;</TD></TR><TR><TD CLASS="quote">Its a whine, something mechanical it gets louder and you go faster, almost like the whine of a supercharger just quieter, its annoying as hell...</TD></TR></TABLE>
Its the trans, love the sound. All good transmissions have a whine to them dont worry.
Old Nov 6, 2007 | 05:24 PM
GYR0's Avatar
I've heard this too...I kinda like it...it's like having a turbo (or SC) under the hood. I just thought it was the engine. Why do "all good trannies make this sound"?
Old Nov 6, 2007 | 10:56 PM
Bboy_Burst's Avatar
Its The Result Of A Miss Shift, Well For Me It Is. The Sound Was Never There Until I Miss Shift From 2nd To 1st @ 8100 RPM.
Old Nov 7, 2007 | 05:25 AM
PostIt's Avatar
Default Re: Transmission Whine?? (Bboy_Burst)
Doubtful, my trans had made that noise since the day I bought the car, and a mis shift grids the syncros its not usual to actually grind down the gear...
Old Nov 7, 2007 | 06:39 AM
H22EG413's Avatar
It's just the sound of the gears meshing, we all have it.
Drive gears are cut at an angle to reduce noise but theres always going to be some.
For example, when you're in reverse that is the sounds of the gears meshing, the only difference is that reverse gears are cut strait: | instead of at an angle /
There is no such thing as a perfectly quiet manual tranny.
Edit- Also I doubt you got the whine from grinding gears, you're just more paranoid now. This is because when you shift gears you're locking in the "dog teeth" of the gear hub. This means when you grind you're grinding them, they are LOCKED in place they don't MESH like the actual gears do.
If you blew up a bearing and threw metal through the entire tranny and scored up the actual gears, then you'd have a louder whine. Grinding gears shouldn't make a whining condition.
Old Nov 8, 2007 | 06:14 AM
PostIt's Avatar
Default Re: Transmission Whine?? (H22EG413)
Nice write up thanks!!
santacruzccs
Aug 15, 2007 02:14 PM
De_tour
12
Aug 3, 2007 05:55 PM
hybrider
Nov 23, 2005 09:25 AM
Pompiuses
Mar 30, 2005 10:06 AM
JDEM1
Aug 4, 2003 08:24 PM
