Window trim questions...
Old Nov 6, 2007 | 06:24 AM
GO-FIGHT-KILL's Avatar
Default Window trim questions...
I'm getting my car ready for paint in the next few days, and I'm starting to look at this trim around the windshield and quarter glass... It doesn't look fun.
I found this thread to be useful, pertaining to the windshield.
Is the upper strip really that hard to remove/install?
I found this thread to be useful, pertaining to the quarter glass.
Does the quarter glass really need to come out, just to remove the trim?
Damnit this paint prep just got a lot more involved if this is true.
Old Nov 6, 2007 | 06:27 AM
migs's Avatar
Default Re: Window trim questions... (GO-FIGHT-KILL)
Are you doing it yourself or is your car in the hands of a body shop?
Old Nov 6, 2007 | 06:46 AM
get RIGHT's Avatar
Default Re: Window trim questions... (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Are you doing it yourself or is your car in the hands of a body shop?</TD></TR></TABLE>
He is trying to do most of the prep himself before it goes to the body shop.
Old Nov 6, 2007 | 08:59 AM
He is trying to do most of the prep himself before it goes to the body shop.</TD></TR></TABLE>
^ Bingo.
It's saving me $1,000 to do the sanding and dismantling myself.
Anyone have any ideas about this?
Old Nov 6, 2007 | 09:20 AM
dyingwish's Avatar
The upper strip isn't that tough, but those little clips break very easily. Just be prepared to replace most of the windshield ones.
As for the quarter window, technically you can remove just the weatherstrip portion, then use a heat gun with straight-razor to clean it off. Don;t worry about over spray on the glass at all, a razor will take it off.
On the other hand, since it is your R....I'd just pull the glass in the quarter window. It the weatherstrip heavily oxidized?
Old Nov 6, 2007 | 09:25 AM
^ I thought the upper strip was attached to the windshield? The side strips are just clipped in, I'm not worry about those.
All of my trim pieces are in great shape, still black as can be, no faded/oxidized spots at all.
I've been thinking about having a local glass company come and remove all of the glass... I wonder how much they'd charge to do that? Also, I wonder how much they'd charge to reinstall... I can't imagine it being that much.
Think I can get away with leaving the trim in, seeming as I'm going to the exact same color, just with a clear coat?
Old Nov 6, 2007 | 09:33 AM
dyingwish's Avatar
Default Re: (GO-FIGHT-KILL)
You're right, the upper is attached.
IIRC, my local auto glass installer came to my house, took out my cracked windshield, and replaced it. The total labor was only $125, which was about two years ago.
It shouldn't be too costly, pale in comparison to painting the whole car. Iassume you're skipping the jambs/bay/etc?
Old Nov 6, 2007 | 09:44 AM
^ Yes, honestly, if I'm going to have to pay $125 just for the windshield, and God knows how much for the quarter glass, I'll just have the car painted around the trim. I had this done with my Civic, and it turned out just fine, the clear never chipped away, and the paint job was a color change from the existing color.
I hate to think of it as cheaping out on my caR, because I've never done that... But honestly, is it going to matter? It's the same color.
Old Nov 6, 2007 | 10:01 AM
R-box's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">^ Yes, honestly, if I'm going to have to pay $125 just for the windshield, and God knows how much for the quarter glass, I'll just have the car painted around the trim. I had this done with my Civic, and it turned out just fine, the clear never chipped away, and the paint job was a color change from the existing color.
I hate to think of it as cheaping out on my caR, because I've never done that... But honestly, is it going to matter? It's the same color.</TD></TR></TABLE>
I've have PY over PY (I'm still not sure exactly what was repainted though...) and a liiiiittle chip-away around the edge of the trim. This is actually back at the bottom of my quarter glass. Previous owner strikes again...
Old Nov 6, 2007 | 10:12 AM
Damnit...
So there's no easy way around this then, huh?
Old Nov 6, 2007 | 10:17 AM
jomama's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">I hate to think of it as cheaping out on my caR, because I've never done that... But honestly, is it going to matter? It's the same color.</TD></TR></TABLE>
... i'd see it as that. i had my old accord repainted a different color and then repainted in certain areas a second time and the paint started chipping all over the place. i think my main issue was that the painter cheaped out and didn't sand down the previous paint. if i were to repaint my R or any car really worth a paint job, i'd take the time and remove all the trim. it'll be a HUGE PITA to do so up front, but you'll totally thank yourself in the end. good luck with the project.
Old Nov 6, 2007 | 10:31 AM
Well, I'm not cheaping out, that's for sure... Damnit, this is going to suck.
Old Nov 6, 2007 | 10:34 AM
Doostur's Avatar
Not worth saving 1,000 if there is a chance I can screw something up When it comes to paint I take no chances. Drink a beer and cough up the extra 1k tubs.
Old Nov 6, 2007 | 10:36 AM
Don't have it right now man, and it's slow season, it will be a while before I'll have it.
Can anyone think of an EASIER way of removing the window trim/molding? I just need to get it removed in the next day or two.
Old Nov 6, 2007 | 10:46 AM
Ok, this is quickly adding up, just called around, and the best price I could get:
-Windshield removal/reinstallation: $125
-Quarter glass removal/reinstallation: $65 a piece
-Rear glass removal/reinstallation: $100
So that's $355 on top of the $500 for paint... What a pain in the ***. And that windshield price is assuming the glass doesn't break on removal, if it does break, he said they'd cut me a deal on new glass, it would be around $240 total for the windshield labor and parts then. It's normally closer to $300 or so.
It's looking like it's more effort than it's worth right now, for a car that really doesn't NEED paint.
Old Nov 6, 2007 | 11:02 AM
Doostur's Avatar
^ Welcome to the biggest money pit of your life sir.
Old Nov 6, 2007 | 11:08 AM
Well I know how expensive cars are, I just didn't realize what a bitch it was to remove these trim pieces. It's bordering on being not worth it.
Old Nov 6, 2007 | 11:17 AM
len's Avatar
len
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">^ Welcome to the biggest money pit of your life sir. </TD></TR></TABLE>
Second to biggest...I want to say Marriage and Kids are up there.
Mr. , suck it up and just do it. We outsource a windshield company to come in to repair all of our windshields. Get it done right the first time.
Old Nov 6, 2007 | 11:26 AM
Well that's what I'm saying, I don't want to it, if it's not done right. And sad to say, I don't have the extra $355 right now to get it done right. This town just dies this time of year, I can't be spending like I do during the summer.
I'll figure it out.
Old Nov 6, 2007 | 11:49 AM
len's Avatar
len
Seeing as how big you are and all, let's just say you do two nights out of the weekend at the local bar as a boucer. That's about $75-100 a night.
So if you work one month straight, that's about $300-400 just right there. Now here's the kicker, if you hit on all the ugly girls at the bar, you may get additional tip.
Old Nov 6, 2007 | 11:51 AM
get RIGHT's Avatar
Default Re: (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">So if you work one month straight, that's about $300-400 just right there. Now here's the kicker, if you hit on all the ugly girls at the bar, you may get additional tip. </TD></TR></TABLE>
LMAO. Leave it to Len to resolve the problem.
Old Nov 6, 2007 | 11:52 AM
Doostur's Avatar
I dont get it.
Old Nov 6, 2007 | 12:02 PM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">I dont get it.</TD></TR></TABLE>
Aren't you suppose to be searching for my Domokun Action Figures?
Old Nov 6, 2007 | 12:07 PM
Doostur's Avatar
Default Re: (len)
Aren't you suppose to be searching for my Domokun Action Figures? </TD></TR></TABLE>
You never sent me a picture of which one you wanted!
Old Nov 6, 2007 | 12:14 PM
Default Re: (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">Seeing as how big you are and all, let's just say you do two nights out of the weekend at the local bar as a boucer. That's about $75-100 a night.
Haha, I work at a bar already duder, it's my 3rd job.
I'll just keep saving until I can do it CORRECTLY. There is no reason to do it half ***.
