gsr in a 97 civic help
Old Nov 6, 2007 | 05:00 AM
ptnguyen's Avatar
Default gsr in a 97 civic help
okay we got a 97 complete motor swap and we put it in a 97 civic ex. We used the ex wire harness and the gsr ecu everything works fine but the rev limiter is at 7600. Is it supposed to be like that? In my si its at like 8200 give or take. He said I need to get the ecu chipped.
Old Nov 6, 2007 | 05:10 AM
skcivic4life's Avatar
Default Re: gsr in a 97 civic help (ptnguyen)
your gauge cluster is redlined at 7600 or your engine hits the reve limiter at 7600
best bet is to get an SI gauge cluster, it will plug right in and it will have the correct redline.
Modified by skcivic4life at 9:43 AM 11/6/2007
Old Nov 6, 2007 | 05:15 AM
ptnguyen's Avatar
Default Re: gsr in a 97 civic help (skcivic4life)
it has a si gauge cluster, its limiting at around 7600
Old Nov 6, 2007 | 06:47 AM
Bazza's Avatar
is it a usdm gsr or jdm? makes a difference.... usdm redlines around 76-7800 and jdm about 8500.
try that out...
yea you can get your ecu chipped to make it rev out farther but its really not all that much worth it
Old Nov 6, 2007 | 08:20 AM
ptnguyen's Avatar
Default Re: (Bazza)
I though even though the redline is at 7.6-7.8 it would go to at least 8.2 before it stops bogging at its limit like my si, both are usdm
Old Nov 6, 2007 | 08:57 AM
mckrank313's Avatar
Default Re: (ptnguyen)
are you using the obd2a p72? because it does hit rev limit around 7600-7900 somewhere in that range... and if you are using the obd2a p72 you can't chip it, you'd have to hondata or some other aftermarket tuning tool or system.
I have a gsr in a 96 coupe and what i did was just threw on the obd2a to obd1 conversion harness and threw on the obd1p28 don't know what it redlines at but powerband isn't affected...
hyper em1
Northeast (Sales)
Apr 17, 2010 04:43 AM
hypeR_ash
Mid-Atlantic (Sales)
Mar 20, 2007 05:55 PM
W0oT
Aug 18, 2002 09:19 AM
uNF$@#!
May 23, 2002 10:19 AM
