1989 accord LX-i issuses
Old Nov 6, 2007 | 04:57 AM
Dolby_Juan's Avatar
Default 1989 accord LX-i issuses
My 1989 accord LX-i has had a funny idle since I bought the car 2 weeks ago. the rpms go up to 1600 and drop back down to 700-900 area depending on how warm the car is. it has 245,7** miles on it so but the engine was swaped with a more in shape A20A3 so the engine only has about 75,000-100,000 miles. Is there anything i could do to stop it like gaskets, fluids, or anything?
Old Nov 6, 2007 | 12:38 PM
moonjaw2002's Avatar
Default Re: 1989 accord LX-i issuses (Dolby_Juan)
How cold is the outside temps.When cold it will start with a fast idle and after warming a bit the idle will go back to normal.
Mark
Old Nov 6, 2007 | 12:57 PM
Fern413's Avatar
Default Re: 1989 accord LX-i issuses (moonjaw2002)
are you low on coolant???..if not it could be your IACV
Old Nov 6, 2007 | 09:09 PM
dtapia's Avatar
Default Re: 1989 accord LX-i issuses (Fern413)
check the pcv valve they are known for sucking the spring and plunger into the intake and will cause a idle like that also check the intake manifold gasket also a know problem with the 86-89 accord lx ,lxi,dx models
Old Nov 8, 2007 | 11:42 AM
Dolby_Juan's Avatar
Well the temperature outside when i got the car was about 60s now its down to 40s for a high and for the car engine its normal for the car it doesnt overheat or anything.
Coolant is fine idk about the IACV yet....
i think it may be the gasket in the intake manifold... its stock and the old owner told me that he never really took care or the engine. He said that he only changed the oil, air filter, and battery.
Is there any chance that the ground wire thats on the accord could have an affect on this? I changed it out from a 10 or 8 guage wire that was onlt holding together by 5 threads or so to a 4 guage wire now.
Old Nov 9, 2007 | 04:50 AM
dtapia's Avatar
which ground wire are you talking about ? the one on the valve cover ? if the battery ground cable was bad the engine would propably not engine start since their is not a good ground.the best way to check the manifold is to spray some carb cleaner at the intake manifold where it bolts up. IACV valves do fail also so yes their is a possiabilty of a bad valve also or the root of the problem.
Old Nov 9, 2007 | 07:13 AM
Dolby_Juan's Avatar
The ground wire that was from the valve cover to the body. i dont think that would really mess the car up that much if any.
Old Nov 9, 2007 | 06:50 PM
dtapia's Avatar
not at all that is more for noise reduction in the electrical.
Old Nov 10, 2007 | 09:05 AM
Dolby_Juan's Avatar
It was the manifold i fixed it up last night. i also put some fuel injection cleaner and it runs alot smoother now.
thanks for the help
bdmlilburn
Oct 21, 2013 06:53 AM
nrmskate
Sep 10, 2013 08:28 AM
unhappy_idle
Feb 13, 2006 06:50 AM
chrispaul
Mar 19, 2004 06:38 AM
crudmuffin
Nov 19, 2003 06:43 AM
