anyone running a f series with p28? or other chipped ecu?
Old Nov 5, 2007 | 07:22 PM
AK_CRX's Avatar
Default anyone running a f series with p28? or other chipped ecu?
Im planning to boost my f22b1 vtec and since there really isn't any tuning software for the poa I plan on switching to p28, I have a stock .bin for a f22b1 to be used in a p28. Just wondering if anyone is running this with good results since the p28 lacks a lot of sensors that the poa uses like EGR, FIAR (fuel injection air control solenoid, and IAR (intake air control solenoid valve)
Question in a nutshell, is anyone running something like this, and how well did the engine accept it?
Old Nov 5, 2007 | 07:55 PM
hahaha38's Avatar
The p28 runs pretty good on a Fseries.Actually it runs like it was made for it.LOL
Old Nov 7, 2007 | 11:23 AM
AK_CRX's Avatar
Default Re: (hahaha38)
anybody have anything maybe a little more insightful?
Old Nov 7, 2007 | 01:39 PM
twkdCD595's Avatar
Default Re: (AK_CRX)
I run a chipped p28 and hondata on my f22b1. I have no issues what so ever... all I had to do was swap the A6 and A11 pins for the p28 and plug it right in (someone correct me if I am wrong on those pin locations, its been a while).
Now of course it required tuning adjustments to make everything work seamlessly, but that was a given as I am boosted and required that no matter what.
Otherwise though, I dont have check engines, cold start issues, fuel economy problems (other than a lead foot), etc and the car ran great on the p28... no problems once I have a tune for the f in it.
Old Nov 7, 2007 | 02:09 PM
2.3lcivic's Avatar
Default Re: anyone running a f series with p28? or other chipped ecu? (AK_CRX)
I have one in my 92 civic to run my F23A1 it was tuned by locashracing it works good dyno has me at 122HP to the wheels
Old Nov 7, 2007 | 04:32 PM
poid's Avatar
Been running mine on a p28 for close to 4 years now. Runs great, only issue i have is a CEL on deceleration because of ELD (issue specific to non-US accords i believe?)
No performance issues at all once it is tuned (and the pins are swapped as twkd says, 95% sure they are the right ones but its been a while for me too).
Old Nov 7, 2007 | 04:45 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
no issues in mine..I used a base map from a F22a6 and had vtec disabled in my f22b1 had no issues......jsut make sure that you have a similar basemap and youll be fine now
Old Nov 7, 2007 | 04:56 PM
oem_certified_accord's Avatar
Default Re: anyone running a f series with p28? or other chipped ecu? (I got the CD5 Jeebies!)
can i run that f22a6 base map on my f22b? (with some minor changes to my satisfaction of course)
Old Nov 7, 2007 | 05:02 PM
Default Re: anyone running a f series with p28? or other chipped ecu? (oem_certified_accord)
meaning what??? my vtec at the time wasent hooked up...and it happened to be the only basemap close to a F why you need a copy???
Old Nov 7, 2007 | 07:43 PM
send if u feel jittery. i'm beginning to look them over and understand how one owner tunes his/hers different from the next.
legendofasaint37@yahoo.com
Old Nov 8, 2007 | 03:43 PM
gonna take me a sec but sure Ill PM you it
Old Nov 8, 2007 | 08:39 PM
Default Re: anyone running a f series with p28? or other chipped ecu? (Mr Wonderfull)
not your fatty....JDMs F22a6 basemap...and you better watch your language tubby you aint got to many % left to lose LMAO
HondaGuy951
Engine Management and Tuning
May 16, 2008 02:45 PM
GSR_hatch936
16
Oct 26, 2007 05:15 PM
sireg6
Apr 25, 2007 02:08 PM
nota-eg
Jun 24, 2005 08:28 AM
TorganFM
Dec 4, 2003 11:16 AM
