Suspension & Brakes Theory, alignment, spring rates....
what shock/coilover setup would u recomend?second thinking koni/gc
Old Nov 5, 2007 | 07:15 PM
jxhxb's Avatar
Default what shock/coilover setup would u recomend?second thinking koni/gc
well i thought i was hearing a lot of good things about koni yellows and gc..i was going to buy the setup from weaksauce with two top hats because im going to dump my eg. so that would of been 975 shipped.
people are telling me the stiffest setting isnt even stiff enough if im dumped?
i dont know how stiffi need to go or how stiff it is
its just now im hearing some negative things about koni /gc and people said i could get a full coilover setup for as much as im paying for the koni/gc setup
what would u recomend for decent ride quality and being dumped i want to be about this low
[IMG][/IMG]
i havent heard much about tein?
any suggestions
im a noob at this and i just dont want to waste my money
THANK U!!!!!!!!!
Old Nov 5, 2007 | 07:19 PM
jxhxb's Avatar
i just read that you haveto cut your stock shock cuz koni yellows are just inserts?
wow really?
well is that a pain?
suggestions please
thanks
Old Nov 5, 2007 | 08:30 PM
slammed_93_hatch's Avatar
Default Re: (jxhxb)
you are reading information that is not correct.
You aren't going to get a decent ride at that height what so ever.
The spring holds the car up, the shock controls the springs.
Modified by slammed_93_hatch at 9:56 PM 11/5/2007
Old Nov 5, 2007 | 08:46 PM
bmoua's Avatar
either GC/Koni, PIC's or Skunk2 Pro-C's.
clean eg....
Old Nov 6, 2007 | 03:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: what shock/coilover setup would u recomend?second thinking koni/gc (jxhxb)
You cannot get a decent ride quality when lowered that much. That's all there is to it. If you want to ride that low you'll just have to live with the crappy ride.
For some strut applications, the Konis are just inserts. This is not the case with Honda applications.
I don't think there is a full coilover on the market that has a damper that is as high quality as the Koni damper that's in the same price range as the Koni/GC setup. That's why so many people swear by Koni/GC. The quality is hard to beat.
Old Nov 6, 2007 | 06:21 AM
gabebauman's Avatar
Default Re: what shock/coilover setup would u recomend?second thinking koni/gc (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">You cannot get a decent ride quality when lowered that much. That's all there is to it. If you want to ride that low you'll just have to live with the crappy ride.
I don't think there is a full coilover on the market that has a damper that is as high quality as the Koni damper that's in the same price range as the Koni/GC setup. That's why so many people swear by Koni/GC. The quality is hard to beat.</TD></TR></TABLE>
Old Nov 6, 2007 | 06:23 AM
verycleanhatch's Avatar
there is no cutting involved in in putting on koni's. you would only half to use the brake line bracket from your stock shocks and that's it(unless you do the shock fork mod). since your getting the top hats too you would basically take your old suspension off and put your new suspension in.
from what i have read on here... with ext. top hats will make your ride smoother with that drop you are looking for. You can also do the fork lowering trick(lowering the shock more into the fork) in the front to get more travel.
also the ssp3's aren't really that different from the regular koni's performance wise. i would get the regualar koni yellows then the ssp3's
the cheapest prices i have seen it are these.
for the koni shocks i reccmend you buy it here.
http://www.hondamarketplace.co...35513
for the gc's with custom rates and top hats i reccomend this guy
http://www.hondamarketplace.co...31489
truehonda.com reccomend these rates
Our Ground Control Rate Suggestion:
Street Use Only: 290/350Lbs
Street/auto-x: 350/380Lbs
Street/Road Course: 380/450Lbs I would go for these ones for the drop you looking 4. to have it less rough you should get 450front/380rear.
Modified by verycleanhatch at 7:58 AM 11/6/2007
Old Nov 9, 2007 | 11:08 PM
team1320_k26eg's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">either GC/Koni, PIC's or Skunk2 Pro-C's.
clean eg....</TD></TR></TABLE>
skunk2 ftmfw
Old Nov 10, 2007 | 10:58 PM
LowTEC_ZX3's Avatar
koni g/c is a really good setup. it handles great and just love the ease of adjustability.
Old Nov 11, 2007 | 12:51 AM
wishone's Avatar
Default Re: (LowTEC_ZX3)
i order omni power coils and KYB AGX's a couple days ago i'll let you know how they ride when i get them on
BTW any recomendations with my setup?
raphael
14
Apr 3, 2008 01:36 PM
tthomass
Suspension & Brakes
Feb 25, 2005 02:28 PM
zijiejijeijrkjk
Jul 18, 2003 09:38 AM
DR.DRum
Mar 20, 2003 05:27 AM
