is it possible to use a b series transmission on a k-series k20a2 k20z3?
reason1 i have a spare b series tran with a quiafe and an adapter plate would be cheaper than k series tranny
reason2 i have an em1 i wana swap in a k20a can i use my b series transmission
pick1
pick1
additionally i have heard of more k series transmission complains then b series. i guess the 05+ have decent final gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madlion »</TD></TR><TR><TD CLASS="quote">is this possible?</TD></TR></TABLE>
i'm sure there is a way but nobody is going to waste time doing it...
it's not possible until someone comes up with a plate for a K to b tranny but i wil highly doubt that will ever happen as the K tranny is good as itself. Also usually a k swap comes with a tranny. It's hard to find those ones that don't have a tranny.
thanks for the replies. my conclusion based on what you all have said is it would be too exspensive for someone to make a plate due to the lack of economies of scale with regards to the demand for this product because most k series swaps come complete with a crap tranny.
More work then its worth and probably end up costing more $ then just buying a K-series tranny. The tranny is "technically" spinning the opposite direction too. That's might cause a reliability/longevity issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice-aronie »</TD></TR><TR><TD CLASS="quote"> The tranny is "technically" spinning the opposite direction too. </TD></TR></TABLE>
I forgot about that. So could this even be done?
umm, no! the DC5 trans is great, plus the little facts like the K20 is a bigger engine, it has a different spline input shaft, the B-series is 5 spd with taller gears, plus the most important fact is that the two motors are mounted 180 deg and the B would spin backwards.
so stick with the rsx / si trans
PrestonCRX
Mar 9, 2006 06:07 AM
lol
