Information about auto to manual conversion
Does anyone here have a run down of the parts needed for a 5spd conversion for a D16Y8? Any good websites that explains this conversion?
Thanks
Thanks
also heard that your intake manifold is different then the manual version and will cause problems . just run a quick search and you should be able to find the post
ECU
Linkage
Tranny
Tranny mounts
Clutch
Flywheel
Clutch Master cylinder
Clutch Slave cylinder
Resevoir
Hardlines and brackets
Pedal Assembly
[Modified by JV, 1:16 PM 6/23/2002]
Linkage
Tranny
Tranny mounts
Clutch
Flywheel
Resevoir
Pedal Assembly
Campee
Dec 12, 2003 10:23 AM
) tranny, clutch, clutch m/c pedal assembly... ecu...hmm...don't know what else
