bolt-ons for b16a2
Old Nov 5, 2007 | 03:56 PM
SOHCcivic97's Avatar
Default bolt-ons for b16a2
hey im doin a J-spec b16a2 SiRII obd2 swap in my ek.
what would be the best/recomended bolt-ons for a b16a2?
also what tranny would be better with the SiR
1. stock SiR tranny?
2.GSR tranny ? and why.
Thank's in advance guy's.
CHEERS!!
Old Nov 5, 2007 | 04:26 PM
ekb16's Avatar
its your car do whatever you want with it..you can always start out by gettin intake, headers, exhaust for starters..
Old Nov 5, 2007 | 04:29 PM
crazyguy's Avatar
Default Re: bolt-ons for b16a2 (SOHCcivic97)
stock sir 2 and gsr have similar short gears..and both of them have optional LSD
Old Nov 5, 2007 | 04:31 PM
but im not to sure what companies to go with that perform better with the b series. cuz im comming from a Dseries motor...lol just not too sure what I/H/E perform better or what not with a b16a2.
Old Nov 5, 2007 | 04:32 PM
Default Re: bolt-ons for b16a2 (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">stock sir 2 and gsr have similar short gears..and both of them have optional LSD</TD></TR></TABLE>
so then they are the same tranny pretty-much? and neither one is better than the other?
Old Nov 5, 2007 | 04:57 PM
Prism250's Avatar
Go with your stock SiR tranny, it has the shorter gear ratios that go along with the B16 engine. Dont know why you would pick a GSR tranny, maybe if you wanted a slower car
Old Nov 5, 2007 | 05:30 PM
electron_si's Avatar
Default Re: bolt-ons for b16a2 (Prism250)
i run CTR intake cam gsr exhaust cam I/H/E and tune on my b16a2 and i put down like 157 to the wheels
injen sri/greddy header/apexi ws2 with test pipe.
just to give you an idea about power range...
Old Nov 5, 2007 | 05:59 PM
what were the tq gains? any??
so when i change the cams etc.. i can go get it tuned?? and see/feel a nice amount of power out of it.
Old Nov 5, 2007 | 06:03 PM
justinrl613's Avatar
get an lad tranny....a lil more $$$ but worth it
and my friend put about $1,000 worth of bolt on on his civic and only got around 30hp gain...
but then he spent $300 and got his head ported and polished and ended up with 80 hp gain in the end....
bolt ons are good but think of it this way...if you get a BIG intake manifold, and a nice set of headers....its not going to make a diffrence if the holes in your head are still small oem....
get it ported then work from there
Old Nov 5, 2007 | 06:04 PM
Default Re: bolt-ons for b16a2 (justinrl613)
***LSD GSR tranny
Old Nov 5, 2007 | 06:07 PM
so then what would be a good bore size to go with?
Old Nov 5, 2007 | 06:16 PM
Default Re: (SOHCcivic97)
well im not sure how much bigger he went....
i know it depends on how much you want to spend....the bigger, the more time it takes, the more money..
take it to your local machine shop and ask what they think.
Old Nov 5, 2007 | 07:33 PM
Prism250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinrl613 &raquo;</TD></TR><TR><TD CLASS="quote">***LSD GSR tranny</TD></TR></TABLE>
Your telling him to get a GSR tranny for his B16? What are the benefits for that?
Old Nov 5, 2007 | 07:37 PM
just about the same gear ratio's,
but from experiance the gsr trannys last longer...and are better if you can find one
Old Nov 6, 2007 | 07:49 AM
Prism250's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinrl613 &raquo;</TD></TR><TR><TD CLASS="quote">just about the same gear ratio's,
but from experiance the gsr trannys last longer...and are better if you can find one</TD></TR></TABLE>
Gear ratios are not the same, the B16's are shorter which help that torqueless motor. Last longer? I dont think he'll be driving the car for 200K miles all these transmissions have the same reliability. Their not just better, a B16 tranny will be suited best for his motor.
Old Nov 6, 2007 | 07:58 AM
skateboard_ej8's Avatar
im hench irl
How long have you "driven" a LSD gsr tranny? You must of had it for quite sometime.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinrl613 &raquo;</TD></TR><TR><TD CLASS="quote">.. experiance ..</TD></TR></TABLE>
Spelling owns. Experience.
Old Nov 6, 2007 | 08:22 AM
BryanM.'s Avatar
Resident Gearhead
Wrong, wrong, and wrong. Don't listen to this guy.
Old Nov 6, 2007 | 08:47 AM
92civicx's Avatar
Default Re: bolt-ons for b16a2 (mcvtec)
stay with a b16 tranny. gsr tranny on a b16 with bolt ons
Old Nov 6, 2007 | 11:07 AM
10-4! so what are the best companies as far as performance wise for the b16a?
Old Nov 6, 2007 | 01:07 PM
92civicx's Avatar
hytech,jun,spoon,mugen,skunk2
Old Nov 6, 2007 | 01:18 PM
crazyguy's Avatar
JDM 92-00 SiR/CTR gear ratio 3.230 2.105 1.458 1.107 0.848 3.000 final drive is 4.400
94-01 GSR ratior is 3.230 1.900 1.360 1.034 0.787 3.000 final drive is 4.400
Old Nov 6, 2007 | 01:21 PM
JDM_902's Avatar
Default Re: (92civicx)
I'm gettin a B18 next week if all goes well and I'm gonna stick with skunk2 for most of my bolts on. I haven't looked into any other companies much but skunk2 know what they're doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinrl613 &raquo;</TD></TR><TR><TD CLASS="quote">get an lad tranny....a lil more $$$ but worth it
but then he spent $300 and got his head ported and polished and ended up with 80 hp gain in the end....</TD></TR></TABLE>
wow, I didn't think it would make that much of a gain from port and poishing! I'm definltey gonna look into that now to...
Old Nov 6, 2007 | 01:30 PM
b17eg's Avatar
Default Re: (JDM_902)
i have a b17(same thing pretty much) i have i/h/e throttle body,aem alt pully with an eriks racing ecu and put down 159whp and 117wtq
Old Nov 6, 2007 | 09:25 PM
Prism250's Avatar
Default Re: bolt-ons for b16a2 (esco562)
Glad some people came in here, to agree that a GSR tranny and a B16 are different.
GSR tranny on a stock B16=
Old Nov 6, 2007 | 10:41 PM
alright then, what if i turbo the b16 should i still run the stock tranny or run a gsr or tci tranny?????
