accord problem
its my dads accord and i just cant figure it out it need a auto tranny so the mechanic had put it in and when the car is cold i try to crank it and it doesnt want to crank i have to do it a few times like about 3 6 times with my foot on the accelerator all the way to the floor and then it starts and drives very nice other than that problem it sound like it off timing but i checked and it is not it. its right on the money so i dont know what to do o and the mechanic change the water pump if that matters so what do you guys think
what do you mean by dosent crank?
if it does not turn over at all it is one of the following things
1. bad starter
2. bad starter relay
3. open wire in system
4. battery/alt charge issue
5. ignition switch failure
1. bad starter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmydan honda man »</TD></TR><TR><TD CLASS="quote">i have coilovers and my rack and pinion is bad can i just raise the car to fit the proper height of the stock shocks</TD></TR></TABLE>
You need to create your own thread please.
it is a 94 honda accord if the car was hot it will crank over with know problem but if it is cold it is hard to crank.when i try to crank it it sound like the dizzy was bad but it had spark
r_u_live
Honda Accord (2013 - 2015)
26
Aug 13, 2018 07:14 PM
