OVERHEATING COOLANT ISSUE
Old Nov 5, 2007 | 01:18 PM
Mr. Em1's Avatar
Default OVERHEATING COOLANT ISSUE
i just swapped in an ls motor into my si for now. The fan works but it will not stay on unless i use a paper clip to keep it on. THe motor previously had no fan switch on the coolant neck and no thermostat ( for the record it is a b18a1) I put in a new thermostat and the coolant neck with the fan switch. The relay for the fan on the radiator was clicking so i replaced it with another one, still no success. Also my radio doesnt work and my heat is blowing hot air. please anybody with advice besides why did u swap in an ls into an si. this is my daily driver and I would appreciate as much info as possible. thanks for your time in advance
Old Nov 5, 2007 | 01:30 PM
tek9_ej2's Avatar
is your rad cap still good? if it doesnt hold pressure, it will cause it to over heat.simple things like that.
Old Nov 5, 2007 | 02:09 PM
Mr. Em1's Avatar
i have a mugen 1 on there now i will check that
Old Nov 5, 2007 | 04:12 PM
Mr. Em1's Avatar
bump for after class
Old Nov 6, 2007 | 07:49 AM
Mr. Em1's Avatar
Default Re: OVERHEATING COOLANT ISSUE (Mr. Em1)
trying to fix this today
Old Nov 6, 2007 | 08:12 AM
instrument's Avatar
wtf is your question?
your fan isnt supposed to stay on.
and your heat is supposed to blow hot air
so whats the problem?
Old Nov 6, 2007 | 06:50 PM
Mr. Em1's Avatar
fixed the problem
Old Nov 6, 2007 | 07:01 PM
crazyjetsfan22's Avatar
Default Re: (Mr. Em1)
well thats good! i need my paper clip back lol just messing!
hotcivicsi
19
May 15, 2009 01:54 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
bigrballerz
Sep 27, 2006 12:42 PM
stealth civic
Jan 13, 2005 09:03 AM
juicedricer
Jan 21, 2003 04:55 AM
