timing belt help
Old Nov 5, 2007 | 12:50 PM
CPT.PANDA's Avatar
Default timing belt help
ok i replaced the head gasket. before i started i made sure every thing was a t tdc. i took every thing a part. replaced the head gasket. put the head on. put the cams in theen the caps. now heres my problem when i was messing with the tensioner to line every thing up the intake cam wouldn't spin the ex. cam does. any ideas. i hope i didn't bend a valve. it's on a b16a2. all stock. i need help asap. thanks
Old Nov 5, 2007 | 12:52 PM
B16B_coupe's Avatar
HRD PKR
Default Re: timing belt help (CPT.PANDA)
take that cam back apart and re install it, maybe you put it together wrong
Old Nov 5, 2007 | 12:56 PM
CPT.PANDA's Avatar
good idea. i thats what im doing now. thanks. keep the ideas commin
Old Nov 5, 2007 | 01:02 PM
CPT.PANDA's Avatar
k on the cam caps theres numbers 2 3 4 are those suppose to be on the ex side or the intake side.are the arrows suppose to be facing the dizzy or the cam gears
Addicted 2 Adrenaline
Apr 14, 2009 09:07 PM
bradennicely
10
Apr 1, 2009 10:11 AM
hondachris1994
Aug 28, 2008 04:47 AM
VWFAN420
22
Mar 31, 2008 12:02 PM
JDMflavor_EJ
Mar 25, 2004 05:56 PM
