help with accord
Old Nov 5, 2007 | 12:45 PM
em1_racer's Avatar
Default help with accord
my friend bought a 1994 honda accord lx for about a month now. the car was from an auction. when she tried to open the moonroof it got stuck on the "tilt" position and it wont close or open no more. dont really know about the fuse because the windows still work. dont really know whats wrong with it. its her daily driver and it has started snowing a bit here. they took it to the dealer and its going to cost about $700 to repair.
any help would be great
what could be done to temporarily seal it for the moment so no snow or water will get into it?
thanks.
Old Nov 5, 2007 | 12:52 PM
em1_racer's Avatar
Default Re: help with accord (em1_racer)
new help asap
Old Nov 5, 2007 | 01:01 PM
TheMuffinMan's Avatar
He knows where you live!
Accords don't have tilt.......
temporary seal?
tape/towels
Old Nov 5, 2007 | 01:06 PM
em1_racer's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Accords don't have tilt.......
temporary seal?
tape/towels</TD></TR></TABLE>
thanks for the help
Old Nov 5, 2007 | 01:08 PM
out of curiousity does the firend have an aftermarket sunroof?
that would probably cut down on the repair cost
out of factory no accord came with tilt (94-97)
Old Nov 5, 2007 | 01:25 PM
em1_racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">out of curiousity does the firend have an aftermarket sunroof?
out of factory no accord came with tilt (94-97)</TD></TR></TABLE>
no its a factory...i dont really know what position its in.
but it just looks kinda partly opened and closed thats it.
shes at work right now so i cant get a picture
Old Nov 5, 2007 | 03:25 PM
The-Kid's Avatar
Default Re: (em1_racer)
actually I saw one with a tilt at my HS, but it was a sedan. I guess only sedans had that tilt feature in the 5th gen Accords.
To your problem, do you even hear the motor running? I would check fuses. 1 under and 1 in the driver side kick panel. It's to the left of the left foot rest.
Old Nov 5, 2007 | 03:39 PM
em1_racer's Avatar
Default Re: (The-Kid)
yea the accord is a sedan
you cant hear the motor anymore...checked the fuse when it first happened and it was still ok...
Old Nov 5, 2007 | 04:28 PM
Tyte-S's Avatar
Sounds like the motor is bad. Assuming you checked the fuse correctly...(test light or DVOM). Just cuz it looks good doesnt mean it is.
Old Nov 5, 2007 | 05:13 PM
YeuEmMaiMai's Avatar
remove the switch and jump the pins that control the close feature...could be a worn out switch. is it an ASC roof? (American Sunroof Corperation)
Old Nov 6, 2007 | 03:48 AM
TouringAccord's Avatar
H-T Order of Merit
my 95 EX Sedan didn't have "tilt"
Old Nov 6, 2007 | 04:13 AM
cwood1388's Avatar
In the meantime check to see if you have the tool that you can use to crank your sunroof back shut. At least you wont be getting debris in your car.
edit: The tool is usually found in your tool kit where your lug wrench is. there will be a little tap just behind the sunroof that you remove and stick the crank tool in. turn clock wise and volia!
Old Nov 9, 2007 | 07:10 PM
em1_racer's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">remove the switch and jump the pins that control the close feature...could be a worn out switch. is it an ASC roof? (American Sunroof Corperation)</TD></TR></TABLE>
yea its a asc roof
Old Nov 9, 2007 | 07:11 PM
em1_racer's Avatar
Default Re: (cwood1388)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwood1388 &raquo;</TD></TR><TR><TD CLASS="quote">In the meantime check to see if you have the tool that you can use to crank your sunroof back shut. At least you wont be getting debris in your car.
edit: The tool is usually found in your tool kit where your lug wrench is. there will be a little tap just behind the sunroof that you remove and stick the crank tool in. turn clock wise and volia! </TD></TR></TABLE>
do you have to remove the headliner to find it?
Old Nov 9, 2007 | 07:52 PM
em1_racer's Avatar
bump
Old Nov 10, 2007 | 06:45 AM
cwood1388's Avatar
You shouldnt have to. its a little round piece of plastic in the headliner. You pry that piece out and youll see the place where you install that little crank tool... I'll try to take a picture in my buddys if you cant find it
Old Nov 10, 2007 | 09:27 AM
em1_racer's Avatar
thanks for all the help
we were able to manually close it...however we had to put a little hole in the headliner since the previous owner replaced the whole headliner so the little plastic thing wasnt there. so we managed to get it down.
thanks again for all your help
Old Nov 10, 2007 | 10:55 AM
cwood1388's Avatar
Not a problem. at least you dont have to worry about any weather getting in there. take care!
killacam661
Jun 15, 2008 02:46 PM
krytoi
Mar 19, 2007 01:22 PM
PoorToRican
Jan 12, 2004 11:30 AM
