*****IGNITION PROBLEM????? 92 HATCH B18C1***********HELP!
Old Nov 5, 2007 | 11:24 AM
whatcivic's Avatar
Default *****IGNITION PROBLEM????? 92 HATCH B18C1***********HELP!
Took the distributor off and cause a friend needed it to test it on their car. Once we re-installed it back it was fine for about the first 15 mins of driving. Once the car got hot it started to stutter. I had this exact stutter 3 months ago and I changed the plugs at that time and the car was fine until today. We marked the position of the distributor so I don't think timing is the issue or is it? It stutters at idel and under acceleration. Could plugs have gone bad that fast? Do I have to adjust timing using a gun after re-istalling the distributor? What stumps me the car drove fine for a little while and only started stuttering once it got warm.
Old Nov 5, 2007 | 11:49 AM
tealj1's Avatar
Default Re: *****IGNITION PROBLEM????? 92 HATCH B18C1***********HELP! (whatcivic)
what do you mean by stutter? do you mean bogging?
Old Nov 5, 2007 | 01:30 PM
blanco617's Avatar
my car was doing the same thing not to long ago i had to change the ignitor in the distributor.
Old Nov 5, 2007 | 02:37 PM
whatcivic's Avatar
Default Re: *****IGNITION PROBLEM????? 92 HATCH B18C1***********HELP! (tealj1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tealj1 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by stutter? do you mean bogging?</TD></TR></TABLE>
Yes - a bog... like jerking and not accelerating.
Old Nov 5, 2007 | 03:19 PM
nabin's Avatar
try and clean out the dizzy with some electric cleaner! also adjust where the dizzy is. you should be able to adjust the timign from there
HPR
Jul 9, 2012 09:09 PM
ek fan
Jul 4, 2008 04:47 AM
whatcivic
Nov 8, 2007 03:16 AM
baggelis
Feb 13, 2006 08:10 PM
GQ Cowboy
May 17, 2003 07:10 PM
