Problems with Bucking and stalling in a boosted gsr.
Old Nov 5, 2007 | 10:43 AM
drintegra's Avatar
Default Problems with Bucking and stalling in a boosted gsr.
The car is a 96 gsr stock motor boosted to 11lbs. The issue occured yesterday. After about 3 months in the garage I decided to take the car out from one garage to the other. I let it warm, I had to jump start the car as the battery had drained. THe car turned right on and idled. I let it adle for about 10 minuted then took it around the block. I made sure to keep an eye on everything afr, oil, etc.. All was good and the car was running great through a couple of 1st and 2nd gear runs. I decided to take out of my community. When I left I boosted it in 1st and a little in 2nd gear everything all good upto about 7k. When I stopped at the light I noticed my idle went down and the car stalled (the lights dimmed). I thought it was something with the battery as I knew the battery was dead. The car did not even have enough power to crank. I got my other car and jumped it. THe car now turned on but Idled at like 300rpm and would stall. I did this again and held the idle with my foot. and the cel 14 came on. I tried to drive and the car bucked bad at like 1500-2000 with load. I drove like this home. I changed the ecu and re-chipped the ecu and all the same. I will be cheking the iacv as I had a wondering idle sometimes for the past several years that would only come on sporadically.
Has this happened to anyone else? is it the iacv? this is killing me. I took the plugs out and they were fine just rich as I added fuel as it was in the 15-17+ when I was driving between 1-2k rpm. I did not take it higher then 2k rpm.
Old Nov 5, 2007 | 12:58 PM
philafelman's Avatar
Default Re: Problems with Bucking and stalling in a boosted gsr. (drintegra)
try replacing the battery with a known good one. ive seen batteries dead enough to not even keep the car running after being jumped.
Old Nov 5, 2007 | 04:56 PM
EASY101's Avatar
* B A N N E D *
Default Re: Problems with Bucking and stalling in a boosted gsr. (philafelman)
thought the alternator was reponsible for supplying voltage to the entire car after its been started...
Old Nov 6, 2007 | 05:50 AM
drintegra's Avatar
Default Re: Problems with Bucking and stalling in a boosted gsr. (EASY101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">try replacing the battery with a known good one. ive seen batteries dead enough to not even keep the car running after being jumped.</TD></TR></TABLE>
I will try this but I doubt this would cause the issues i described.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 &raquo;</TD></TR><TR><TD CLASS="quote">thought the alternator was reponsible for supplying voltage to the entire car after its been started...</TD></TR></TABLE>
I agree but I also don't see this being an issue as it was a sudden drop in rpms and then bucking like crazy. I took off the iacv and cleaned it out and will try to turn it on tonigh with a good battery. weird crap cause it never did this before and the car has always run great. The IACV had some tiny chunks of carbon in the screan so I am hoping that was the issue. never cleaned it before either.
It almost feels like a sensor went bad all of a sudden dunno which one though
Old Nov 6, 2007 | 05:54 AM
boosted k20's Avatar
check the IACV and also check to see if the alternator belt is still on
Old Nov 6, 2007 | 06:06 AM
drintegra's Avatar
Default Re: Problems with Bucking and stalling in a boosted gsr. (boosted k20)
The alt belt is on and tight. The Alt is plugged in and the battery charged some so I know the alt is charging as the battery was totally dead and after riding for like 5 minutes I can atleast see the lights on in the car when the key is to the on position. I reviewed some of the posts about IACV and the code 14 and people have had weird results. Frustrating as the car has been flawless for the past 7 years. I hope the IACV cleanup did the trick but I have doubts. I will replace it with my other cars to check also. I just never heard of the IACV causing issues like that. Felt like the map sensor was bad or TPS. I also checked the map and it was fine and the TPS read accurately when I looked at the laptop fully closed it was at like 2% and full throttle was at 100%
Old Nov 8, 2007 | 04:50 PM
JaredKaragen's Avatar
check your TPS calibration. Also, look for a disconnected or pinched FPR hose.
slammed98sedan
Dec 25, 2014 07:12 AM
antig24
Jun 27, 2009 10:27 AM
powerdbygarrett
May 7, 2008 10:44 AM
matthevelli
Jan 2, 2006 12:42 PM
Timmay
Feb 27, 2004 04:01 PM
