alternator/battery problem
Old Nov 5, 2007 | 07:12 AM
carlthecrx's Avatar
Default alternator/battery problem
so i was pretty damn certain my alternator went out, but when i took it and my battery to have them tested the alternator was good and the battery was bad.. so i put the alternator back on and about a day later the new battery is out of juice... but the alternator tested good?
Old Nov 5, 2007 | 07:24 AM
CRX Toad's Avatar
Default Re: alternator/battery problem (carlthecrx)
Get a new place to check the alternator. Check ALL grounds.
Old Nov 5, 2007 | 07:28 AM
carlthecrx's Avatar
Default Re: alternator/battery problem (CRX Toad)
checked all grounds, and that is what i was thinking.. thanks
Old Nov 5, 2007 | 07:54 AM
CRX Toad's Avatar
Also if it is found to be bad and you buy a new one make them test it right there (the new one) to make sure it is good. Too many guys get them and put them on to find they were junk out of the box, I found that one out the hard way myself. Two day old alt went out on a road trip luckily I was back where I grew up and had access to tools and hanger.
Old Nov 5, 2007 | 09:12 AM
carlthecrx's Avatar
yeah i know how that is.. my buddy bought a rebuild alternator from autozone a while back and the pully was lopsided.. the guy at the counter insisted that it was just our immagination, so we made them put it on the tester and finally gave us a different one
Old Dec 19, 2007 | 07:57 AM
moodymoe15's Avatar
Sorry if i am jacking your thread, but i have the same exact problem, and the alternator tested good.
How did you get it fixed, what are the grounds that i should have checked, and do you have images of how the grounds look like. I would really appreciate it.
Old Dec 19, 2007 | 03:36 PM
carlthecrx's Avatar
Default Re: alternator/battery problem (moodymoe15)
i took toad's advice and had the alternator tested again, even though it still tested good i went to the junk yard and got another one just for the heck of it, cause i was 99.99% positive the alternator was bad.. and the new alternator did the trick
88 EF Hatch
Sep 17, 2009 07:29 AM
obuhmyuh
May 28, 2008 03:27 PM
eg6madness
Oct 28, 2006 01:37 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
bonta-kun
May 12, 2003 06:08 PM
