Will the H22A OBD2 dizzy fit on my 96 H23
I need to know if I can put a H22A dizzy on my H23 if the H22 dizzy is OBD2.. I know there may be a diff. with the Vtec but I think I could just disconnect anything that I wouldn't need till I get my first check my job. I am tired of the jerking because my P1381 code..
Is there anything I can do if that will not work?
Did the two plugs work?
How did you get a sig on here?
I want to get this on here
Modified by oatmeal and water at 6:43 AM 11/5/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 »</TD></TR><TR><TD CLASS="quote">lol. my lude is a 96 also and the same color..</TD></TR></TABLE>
I thought you claimed to have used a jdm h22 distributor on your swap?
Guest
Posts: n/a
no ill say this again and make sure u read this a few times and take it all in..... my car is a 96 obd2 car.. i used an obd1dizzy i just ran the wires from the crank senser plug to the dizzy.u asked if i threw a random missfire code running a obd2 ecu i said no i didnt
You can use the obd1 dizzy on a obd2 car but you have to run wires for the CKY and CYP sensors. The obd2 dizzy has them on the oil pump, the obd1 dizzy has them inside of the dizzy.
