h22 swap
Old Nov 4, 2007 | 06:46 PM
slo_hatch's Avatar
Default h22 swap
ok im considering an h22a swap for my 93 hatch. on password:jdm they have a complete swap with motor, ecu, tranny, shift cable, innovative mount kit for 92+ civic, and innovative h-series swap axles for extra. would i need anything else to drop it in? or just get that package and just swap? is there any cutting/grinding/welding or anything that makes this more difficult? just want to clear it up before i order that swap. thanks.
Old Nov 4, 2007 | 07:05 PM
thatboyrob's Avatar
Default Re: h22 swap (slo_hatch)
The only thing you might need is the shifter assy, but then again if your car is already 5spd you're ok. I know some people switch shifter boxes anyways when doing the h22 swap. I did, but if it is a complete swap the only other thing you need are the mounts and axles and a wiring harness if you want it to plug and play otherwise just use your exisiting one.
Old Nov 4, 2007 | 07:12 PM
slo_hatch's Avatar
Default Re: h22 swap (thatboyrob)
it said it came with an innovative mount kit....is that the motor mounts im guessing? and its coming with a wiring harness. and i can get the innovative axles for and extra $350. it sounds like a good priced swap. and i was really contemplating goin h or k series. but h-series are alot cheaper. lol so you think it should just drop in? no hybrid headers or intake manifolds?
Old Nov 8, 2007 | 11:51 PM
DuecedSol's Avatar
What You need is Obviously the H22 and Hasport mounts to mount it, if you use a h-series tranny, you need 90-93 integra axles, Then you need the shifter assembly from a prelude which needs to be welded in place of your stock shifter assembly(you have to cut out the stockie), then the shifter cables. If you feel a lil spunky, you can get the h to b conversion which alows you you to use a b-series trans and your stock shifter assembly.
Old Nov 8, 2007 | 11:56 PM
93egSLEEPER's Avatar
have you driven an h series?? the trannys are stiff and choppy IMO and seem to make it less fun to drive like a b or d series. good torque and power output though.
Old Nov 8, 2007 | 11:57 PM
Syndacate's Avatar
Default Re: h22 swap (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER &raquo;</TD></TR><TR><TD CLASS="quote">have you driven an h series?? the trannys are stiff and choppy IMO and seem to make it less fun to drive like a b or d series. good torque and power output though.</TD></TR></TABLE>
I love the cable trans feeling, it makes me all warm and fuzzy inside...
Seriously though, that choppy, stiff shifting that everybody hates &gt; linkage IMO.
Old Nov 8, 2007 | 11:59 PM
Default Re: h22 swap (Syndacate)
i like the cable feeling also..... stiffer... which is why i ran stage 2 exedy.. for the feel. haha i guess i just havnt driven an h that had a smooth shift linkage setup.... i need to find one now....
Old Nov 9, 2007 | 12:20 AM
F40's Avatar
F40
You need to cut your stock passenger side mount bracket off and have the H-series one put on...
Old Nov 9, 2007 | 12:50 AM
DuecedSol's Avatar
Im not really a fan of the cable shifter, I like the solid feel of b and d series shift linkages...but im not complaining.
Old Nov 9, 2007 | 01:53 AM
Doostur's Avatar
https://honda-tech.com/zeroforum/18
crxbape
Jun 16, 2014 06:00 PM
crazyracer817
Oct 22, 2006 09:29 AM
Monchi
10
Feb 22, 2006 08:11 PM
tltas0325
Apr 13, 2004 08:21 PM
Slow96IntegraSE
Apr 12, 2004 07:06 PM
