wont start
Old Nov 4, 2007 | 06:22 PM
hamst3r3x's Avatar
Default wont start
just swaped a poor mans type r in 89 crx hf. have a chipped obd1 ecu with obd0 to obd1 harness will not start but will start with stock single cam ecu does any one know what is wrong? did check ecu in another car and works fine. please help
Old Nov 5, 2007 | 06:17 AM
JustAnotherRex's Avatar
Default Re: wont start (hamst3r3x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamst3r3x &raquo;</TD></TR><TR><TD CLASS="quote">just swaped a poor mans type r in 89 crx hf. have a chipped obd1 ecu with obd0 to obd1 harness will not start but will start with stock single cam ecu does any one know what is wrong? did check ecu in another car and works fine. please help</TD></TR></TABLE>
Single cam what ecu? The OBD0 HF ecu? If so I'd wonder what's going on with your wiring.
I'd check your wiring and grounds, but that's some funky stuff. Bump for help if nothing else.
Old Nov 5, 2007 | 09:45 AM
hamst3r3x's Avatar
to those with same problem found out that i have to use an obd1 dizzy instead of obd0. you just have to cut the plugs on the obd1 dizzy and wire it straght to the harness.
BROCKMYSTER
May 11, 2010 08:55 PM
scooterbuilteh2
Oct 23, 2009 05:34 PM
cwf1988
Jan 3, 2009 02:11 AM
nelsonb16
Jan 31, 2008 06:41 PM
