Weird Electrical Problem!
Old Nov 4, 2007 | 05:05 PM
br3ak3r84's Avatar
Default Weird Electrical Problem!
I have a 96 Honda Prelude. My horn/brake light FUSE blew and I replaced it. Right as I stepped on the brake, the fuse blows again immediately! I must blown 5 fuses trying to replace it but it keeps happening and I have no horn or brake lights. Anyone know what's going on here??
Old Nov 4, 2007 | 06:17 PM
dtapia's Avatar
Default Re: Weird Electrical Problem! (br3ak3r84)
ok here is a etm page that will break down the circuit if you need more help let me know.
Old Nov 5, 2007 | 08:21 AM
br3ak3r84's Avatar
bump...thanks for the diagram dtapia but I'm still lost as to what's causing it.
Old Nov 5, 2007 | 04:21 PM
dtapia's Avatar
Default Re: (br3ak3r84)
sounds like a dead short. was has been replaced or changed ? have you checked for water leaks in the trunk area near the back lights. have seen the trunk seals leak and the tail light seals also and getting water in the electrical parts like the brake light sensor.you could start with the process if elimanation i would unplug the brake light sensors and see if the fuse still blows and also unplug the brake light switch on the pedal assy.
does the fuse blown if you honk the horn ? or just when the brake pedal is depressed?
Old Nov 5, 2007 | 09:33 PM
civicking99's Avatar
or possibly a bare wire grounding out when you hit the pedal
Old Nov 6, 2007 | 11:53 AM
br3ak3r84's Avatar
aite i'll be sure to dc my brake lights and see if it still blows
Old Nov 6, 2007 | 01:58 PM
Chiovnidca's Avatar
Make sure you have the correct bulbs in it.
Old Nov 6, 2007 | 05:09 PM
dtapia's Avatar
Default Re: (Chiovnidca)
oh yea now im remebering i have seen a filliment break and touch the side if the bulb and blow the fuse but i have only seen it 2 times but weirder things can happen.
Speedybebossin
Nov 8, 2015 02:07 PM
dbailey
Jul 25, 2010 10:24 AM
ek4_b16a
Jul 2, 2009 10:20 AM
prelude_93vtec
Nov 26, 2007 01:57 PM
