B16A Tranny to B18C5 Motor?
Old Nov 4, 2007 | 04:51 PM
itr590's Avatar
Default B16A Tranny to B18C5 Motor?
Will this work? I'm not too familiar with the compatibility of the B motors to B trannies, and my friend is rebuilding a Type R longblock. However, he is considering getting an SI transmission (apparently the gear ratios are very similar to the ITR's). Any advice on what tranny would be best for the ITR (aside from an ITR)? Thanks guys, and sorry if I sound a little ill-informed.
Old Nov 4, 2007 | 04:52 PM
pennies_hatchie's Avatar
Default Re: B16A Tranny to B18C5 Motor? (itr590)
yes
Old Nov 4, 2007 | 04:55 PM
GO-FIGHT-KILL's Avatar
Default Re: B16A Tranny to B18C5 Motor? (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
Myes.
Old Nov 4, 2007 | 04:56 PM
Bradstard's Avatar
Yes it will work. I also have an ITR LSD for sale if he wants one for that Si tranny.
typer_696's Avatar
For future refereces a B is a B. You can swap and mix and match parts as long as it is a B. You will have no problem. Take parts from an ls, si or gsr.
Old Nov 4, 2007 | 06:11 PM
pvt_awol's Avatar
Default Re: B16A Tranny to B18C5 Motor? (typer_696)
so I can put an '01 ITR b-series tranny in my '89 B20a5 equipped Prelude Si?
Old Nov 4, 2007 | 06:19 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr590 &raquo;</TD></TR><TR><TD CLASS="quote"> (apparently the gear ratios are very similar to the ITR's) </TD></TR></TABLE>
The gear ratios are identical.
Old Nov 4, 2007 | 06:31 PM
MOVE OVER's Avatar
Default Re: B16A Tranny to B18C5 Motor? (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 &raquo;</TD></TR><TR><TD CLASS="quote">For future refereces a B is a B. You can swap and mix and match parts as long as it is a B. You will have no problem. Take parts from an ls, si or gsr. </TD></TR></TABLE>
Be VERY careful when saying that.
B16 tranny internals are not compatible with the ITR tranny and probably other B18 tranny's.
Brad, do you know if the LSD will work in a B16 tranny? I don't think that the final drive will, but I am not sure about the LSD.
Modified by MOVE OVER at 8:41 PM 11/4/2007
Old Nov 4, 2007 | 06:51 PM
Bradstard's Avatar
Default Re: B16A Tranny to B18C5 Motor? (MOVE OVER)
I know of MANY people with an ITR LSD in their EM1 Si. I am not sure exactly what is required to install the LSD.
Old Nov 4, 2007 | 07:40 PM
MOVE OVER's Avatar
Default Re: B16A Tranny to B18C5 Motor? (Bradstard)
gotcha. Good to know
Old Nov 4, 2007 | 11:58 PM
EM1 Loi's Avatar
a gsr/itr ring gear will be needed if the lsd doesn't come with it. the b16 ring gear will not fit over an itr lsd.
Old Nov 5, 2007 | 04:09 AM
Stinkycheezmonky's Avatar
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pvt_awol &raquo;</TD></TR><TR><TD CLASS="quote">^
so I can put an '01 ITR b-series tranny in my '89 B20a5 equipped Prelude Si?</TD></TR></TABLE>
I don't think so. At the very least, I THINK your car has a cable-actuated clutch, whereas the ITR trans has a hydraulic clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOVE OVER &raquo;</TD></TR><TR><TD CLASS="quote">
This is true, when talking about internal parts. You need very specific matching gears to FDs to input shafts, etc. Any B-series CASE will work with any B-series gearset. Also, any completely assembled B-series trans will bolt up to a B-series motor and will work fine, assuming the above-mentioned clutch issue.
Old Nov 5, 2007 | 05:56 AM
pvt_awol's Avatar
Default Re: B16A Tranny to B18C5 Motor? (Stinkycheezmonky)
oh, I know for a FACT that you can't do it. The b series in the Prelude has completely different bolt patterns than any other B series stuff.
I just threw that out to be a dick, cause someone said that ANY B series will bolt up to ANY B series. You have to be careful what is typed on the 'net. Young impressionable minds and all.
(speaking of which, that's what made my first b16 swap back in '98 take so long. People on the net with wrong information. Something like this: "Use the '99 Si rear tranny mount in your EG. That is the one you need." ---- and of course, NOW we all know the real truth.)
Oh yeah, the JDM GSR (SiR-G) LSD won't bolt into the b16 tranny. Some ITR ones will, and of course there is a rare B16 tranny LSD. Whoever said that the ring gear is wrong, was right on the money. (there's actually a little snippet about this in the latest Honda Tuning in the "150hp per liter" article.)
Old Nov 5, 2007 | 08:50 AM
Suspetise...
Default Re: B16A Tranny to B18C5 Motor? (pvt_awol)
That's what I thought, but having never dealt with the B20A5 personally, I didn't want to hand out false info
And thanks for making sure everything is correct, you're right in that we do need more of that here on HT.
Old Nov 5, 2007 | 01:24 PM
pvt_awol's Avatar
I agree that we need more "policing" of bad info on H-T, I think that the ITR forum is probably the most "authentic" forum on the board. The guys in here seem to know their stuff VERY well.
Honestly, I think that is why so many noobs come in here to get info, they feel like we are the most mature, and informed, on the board.
jdmjoelol
28
Apr 13, 2006 07:13 AM
wannabejdm
Jan 14, 2005 11:15 AM
stumpyf4
Nov 9, 2004 08:09 PM
civic-si-2000
Jul 16, 2003 01:43 PM
mavrik
Jul 3, 2002 11:47 AM
