What is this part called? and how do I fix this...
Old Nov 4, 2007 | 04:34 PM
br3ak3r84's Avatar
Default What is this part called? and how do I fix this...
I couldn't search for how to fix this problem because I don't know what its called. Bascially, I've had a clutch fluid leak for a while and I replaced both my master and slave clutch cylinders and the hose from the reservoir to the clutch master cylinder. There is still a leak and recently all the fluid leaked out and I was stuck on the freeway with a clutch pedal and stayed down. I looked all throughout the engine bay following the brake lines and found a leak. In the picture is where the leak is located but what is that peice the lines connect into? and how could I fix the leak in this portion??
*sorry about the bad art. I couldn't take a pic becuase it was too dark and all you see is black*
this is for a 96 honda prelude and is a hydraulic clutch.
Old Nov 4, 2007 | 06:01 PM
dtapia's Avatar
Default Re: What is this part called? and how do I fix this... (br3ak3r84)
sounds like the clutch damper is this what you are talking about ?
Modified by dtapia at 7:12 PM 11/4/2007
Old Nov 4, 2007 | 07:09 PM
br3ak3r84's Avatar
yeah thats it. How do I fix the leak coming from it?
Old Nov 4, 2007 | 07:13 PM
dtapia's Avatar
Default Re: (br3ak3r84)
if the hose is not leaking then the unit must be replaced. i must admit i have never seen one leak
Old Nov 5, 2007 | 08:12 PM
dtapia's Avatar
Default Re: (dtapia)
here is the part located and a price 53.00 not bad
here is the web page so it will make it easy to get at honda.
http://www.hondaautomotivepart...INDER
hannslebo
Mar 24, 2009 01:53 PM
afropuffs808
May 2, 2008 06:17 AM
Gomdohree
Apr 24, 2008 06:20 AM
br3ak3r84
Nov 4, 2007 04:50 PM
