i think its my ball joint
how many of u guys have bad lower ball joints on ur eg suspension and what are the symptons. my car pulls to the side a little and i got my steering wheel shaking a bit. i noticed that the dust boot on the lower ball joint was torn and its been like that for a while. if any of u guys have had this prob i would like to know. thanks to anyone who replies.
Get the car in the air and check the joint for play. If the boot has been broken for a while, then the grease probably leaked out and/or was contaminated with dirt. Just as with an axle CV joint, once that happens, you should replace the joint.
Symptoms of a bad ball joint are rattling and/or squeaking over bumps, freeplay in the joint, and wheels falling off while driving.
yeah thats what i thought when my wheel start rolling away but luckily im so good at driving i some how caught it with my hub and drove home safe. just kidding thanks for replying ill do exactly what u said and hopefully that solves my prob. THANX
I had a lower ball joint boot tear on me. There was no pulling or vibration, but instead there was a creaking/popping noise when I would turn the wheel, and only with the car on the ground. When I raised the car up, no noise.
yeah i do get a popping noise when i turn into a dip or a turn that causes stress on the part. do you need a press to get that piece out or do i just hammer that thing out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moz92 »</TD></TR><TR><TD CLASS="quote">yeah i do get a popping noise when i turn into a dip or a turn that causes stress on the part. do you need a press to get that piece out or do i just hammer that thing out?</TD></TR></TABLE>
Depends on your technical prowess.
I've seen it done on the car (on a two-post lift) by just hammering the old joint out from underneath, but I haven't tried it. When I replaced the lower ball joint on my Civic, I removed the knuckle and beat the old one out on the work bench, then pressed in the new one with the vice and a socket. It obviously took longer and required more effort, but I figured I'd probably miss and damage the brake rotor or something if I just started beating on the car with a hammer. I've been known to screw things up like that
chowderhead
Apr 29, 2017 04:24 PM
Endo-land
Mar 16, 2008 07:15 PM
GruvyTune
Jul 22, 2002 10:01 AM
