D-Tranny test
Old Nov 4, 2007 | 02:58 PM
LSVTEC96HB's Avatar
Default D-Tranny test
Ok, I have 8 D series trannys sitting around taking up space in my work area. I hate to throw them all out, since I am sure there are a few good ones. How can I tell if they are good?(without taking them all apart)
Old Nov 4, 2007 | 03:37 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: D-Tranny test (LSVTEC96HB)
the first idea i had is to grab an old axle, put 2 axle nuts on the end so they jam each other, and then use a impact gun to rotate the axle into the trans.. then shift a couple times to see if the input shaft starts moving and go from there..
might be a 2 or 3 person job though..
Old Nov 4, 2007 | 03:52 PM
Max Kling's Avatar
No real good way unless you take the case off an know what you are looking at.
Old Nov 4, 2007 | 04:41 PM
sasinorm01's Avatar
if any are si trannys, ill buy one from you
Old Nov 4, 2007 | 06:45 PM
LSVTEC96HB's Avatar
Default Re: (sasinorm01)
yeah, I think I remember getting an SI and ZC to do the hybrid tranny conversion. I don't know what is what anymore. I'll have to look. I'd really like to get rid of all of them. I planned on doing a D16y8 w/ZC pistons, and the ZC/SI tranny, but I've never gotten around to it. I ended up selling off all the D engine parts, and now I've got a bunch of trannys laying around.
Old Nov 4, 2007 | 06:55 PM
wiZCo's Avatar
Stouts 'n' Scotch
Easy way is to spin the input shaft and listen for any bearing noise (clicking, grinding). And what's stopping you from opening the transmissions? They're sooooooooo freakin easy to crack once you have them out of the car.
Old Nov 4, 2007 | 10:47 PM
sasinorm01's Avatar
well let me know if you have a si tranny and how much you want for it
Old Nov 11, 2007 | 06:19 PM
LSVTEC96HB's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote"> And what's stopping you from opening the transmissions? They're sooooooooo freakin easy to crack once you have them out of the car.</TD></TR></TABLE>
Sheer laziness.
JINX'D
Dec 13, 2007 05:05 PM
EG8R
Aug 3, 2006 07:09 PM
*Boostwerks*
Sep 14, 2003 11:03 AM
rasta420
Feb 14, 2003 07:20 AM
pelotudo
Aug 26, 2002 06:00 AM
