shifter rattle!???
Old Nov 4, 2007 | 12:24 PM
MiamiEgGSr's Avatar
Default shifter rattle!???
ok.. bushing is new , shifter has a bit play to it , but it shifts fine .. only thing is while driving it rattles not a loud rattle but enough to ANNOY THE **** OUT OF ME !!!!!!!!
Old Nov 4, 2007 | 12:26 PM
ke98248's Avatar
Default Re: shifter rattle!??? (MiamiEgGSr)
That's what mine did.. I replaced my stock rubber bushings with Energy Suspension Bushings and tightened up the bolt to my shifter/linkage and it went away.
1992Si's Avatar
Did you remove the heat shield. you may need to do that.
Have you replaced the shifter with a good short throw shifter.
Old Nov 4, 2007 | 12:30 PM
MiamiEgGSr's Avatar
Default Re: (1992Si)
THIER WASNT a at shield...i replaced bushing and shiftet(bearing on short shifer was F up) ..its nott like to loose but loose enough... i cant tighten the screw down their anymore !!!
Old Nov 4, 2007 | 03:34 PM
MiamiEgGSr's Avatar
Default Re: (MiamiEgGSr)
bump for helpo
Old Nov 4, 2007 | 03:39 PM
confucioussae's Avatar
Was your motor swapped before? Check the bitch pin to make sure there is a spring pin in there, and not a bolt! This could make for a reallll sloppy shifter.
Also, a bit of "shaking" is completely natural for the shifter, but it should not make an audible rattle. Pull out your cupholder, and make sure everything is tight down beneath the rubber boot! Check all bolts pertaining to the shifter, make sure they're there, and make sure they're tight!
Chris
Old Nov 4, 2007 | 04:09 PM
MiamiEgGSr's Avatar
Default Re: (confucioussae)
k..thier is a pin but NO SPRING!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 4, 2007 | 04:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiamiEgGSr &raquo;</TD></TR><TR><TD CLASS="quote">k..thier is a pin but NO SPRING!!!!!!!!!!!!!!!!!!!!!!!</TD></TR></TABLE>
There's not supposed to be a spring. A spring pin is just a pin, it just has a special name because it's a special load-bearing pin.
Old Nov 4, 2007 | 04:37 PM
Eran's Avatar
HT White Ops
It's also called a roll pin.
vwtohonda
Aug 7, 2006 08:55 AM
eluder33
Nov 20, 2004 03:05 PM
slash00R
Nov 1, 2004 07:23 PM
Eatvtec97
May 20, 2002 12:56 PM
