white smoke
Old Nov 4, 2007 | 12:04 PM
crx1990Si's Avatar
Default white smoke
i have a 1990 honda crx si and every time i turn it on lots of white smoke pours out of the exhuast when it idles the owner before me told me it burns oil but i need to know whats wrong
Old Nov 4, 2007 | 12:06 PM
Xanok's Avatar
Default Re: white smoke (crx1990Si)
Probally a headgasket. Check and see if your oil is milky. Itll look like chocolate milk.
Old Nov 4, 2007 | 12:08 PM
jeremycrxb16's Avatar
Default Re: white smoke (Xanok)
white smoke usually means coolant being burned. check your head gasket right away before any more damage is done
Old Nov 4, 2007 | 12:13 PM
crx1990Si's Avatar
Default Re: white smoke (jeremycrxb16)
do you know where exactly the head gasket is at
Old Nov 4, 2007 | 12:16 PM
CRX Toad's Avatar
Under the head, which is under the valve color. \
Between the head and block.
Old Nov 4, 2007 | 12:25 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: white smoke (CRX Toad)
usually oil being burned
Old Nov 4, 2007 | 12:42 PM
mistajdm's Avatar
Default Re: white smoke (x4thGenCafe)
prolly the head gasket
Old Dec 16, 2007 | 07:25 PM
lend_type_R's Avatar
i got same situation on my 91 hatch civic DX. but when i check the reservoir for after a day, week and months theres no change in amount of antifreeze and no mixture of oil either. so what else do you guys think that produces that white smoke? as for additional info, i added some oil in between oil change. the total amount of oil i added is less than a quart. but the smoke is not black as mention by other forum if your burning oil.
Old Dec 16, 2007 | 07:27 PM
hondacrxsiguy's Avatar
Default Re: (lend_type_R)
yup, oil burning, or head gasket.
Old Dec 16, 2007 | 07:34 PM
if its burning oil, will there be a possibility of white smoke from the exhaust?
Old Dec 16, 2007 | 09:52 PM
therealzk's Avatar
too much oil?
Old Dec 16, 2007 | 10:25 PM
.Manny.'s Avatar
Touching My Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1990Si &raquo;</TD></TR><TR><TD CLASS="quote">do you know where exactly the head gasket is at</TD></TR></TABLE>
holy ****, just take it somewhere to get repaired. don't lay a hand on it
Old Dec 17, 2007 | 12:10 AM
xxnickpxx's Avatar
Default Re: white smoke (.Manny.)
ok....if its white smoke its water, blue smoke is oil. most likely its head gasket. its most likely going to run around 400 to 500 depending on the shop. also, if its oil when does the smoke come out? idle, after you let off the gas, or hard excel?
Old Dec 17, 2007 | 12:14 AM
clockwork675's Avatar
Default Re: white smoke (xxnickpxx)
Take it to a shop for a leak down test!! That should spread some light on the exact problem
Old Dec 17, 2007 | 08:32 AM
Johnny-Red's Avatar
Default Re: white smoke (clockwork675)
Check the throttle body gasket before you do a head gasket, sometimes the coolant thats ran up there can leak into the TB.
It only take a **** drop of water to make clouds of white smoke. But its most likely the head Gasket.
Old Dec 17, 2007 | 10:30 AM
90efhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clockwork675 &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed.
Old Dec 17, 2007 | 10:43 AM
JdmEG6Si's Avatar
* B A N N E D *
wow this guy must be ignorant!
Old Dec 17, 2007 | 06:57 PM
boosted28's Avatar
time for a b series
Old Feb 16, 2008 | 08:07 PM
dannysolis92005's Avatar
Default Re: white smoke (boosted28)
sorry to bugg in....my car smokes(white) when the fan goes on and the car charges for the fan..also the rpm goes a bit high... its usually at about 600-800rpm when stoped.....then the fan goes on and it goes to like 1000-1500... im runnign a gsr engine!!
Old Feb 16, 2008 | 08:40 PM
soodominican's Avatar
Default Re: white smoke (dannysolis92005)
im not saying anyone is wrong and i dont know if civics and 2007 sti's have anything in common but my brothers sti blows white smoke and he ran a compression check on the pistons and pistons 2 and 4 are losing compression, see it feels any different in the way it drives, you should notice whether its slower or not. if its not any slower i doubt its the pistons than. good luck with that man, but in all honesty just take it to a shop.
DRoylflush
11
Apr 10, 2011 02:11 PM
oldschoollove
53
Jan 25, 2011 04:37 PM
qhondak
Oct 14, 2008 09:27 PM
mafiaboy757
Sep 14, 2005 08:58 AM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
