2000 cx timing belt question
Old Nov 4, 2007 | 09:49 AM
boomnn's Avatar
Default 2000 cx timing belt question
ok i have a 2000 cx " d16y7" i broke the timing belt while trying to start it the other morning and i am wondering if it is a non-interference motor or i f***ed it up !!! any help would be appreciated
thanks neil
Old Nov 4, 2007 | 09:54 AM
forcefedferio's Avatar
Default Re: 2000 cx timing belt question (boomnn)
if you were just trying to start it you are probably OK.
Old Nov 4, 2007 | 09:56 AM
Eran's Avatar
HT White Ops
It's an interference head. At the least, you probably bent a valve.
Old Nov 4, 2007 | 10:10 AM
Syndacate's Avatar
Default Re: 2000 cx timing belt question (forcefedferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio &raquo;</TD></TR><TR><TD CLASS="quote">if you were just trying to start it you are probably OK.</TD></TR></TABLE>
No he isn't. I'd like to remain positive too, but tell it like it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomnn &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 2000 cx " d16y7" i broke the timing belt while trying to start it the other morning and i am wondering if it is a non-interference motor or i f***ed it up !!! any help would be appreciated
thanks neil</TD></TR></TABLE>
All H/A engines (as far as I know, but definitely including the Y7) are interference engines. So you probably roasted a valve depending on a combination how high your RPM were when the timing belt snapped, how fast you killed the engine (or did it die by itself), and how much you tried to start it back up once it was off.
In your case it broke while you were starting it so I gotta ask, how much longer after you started it did you pump it? Probably enough to bend a few valves, unfortunately.
On the flipside, you can probably pick up an entire Y7 head for like 100 bucks.
Old Nov 4, 2007 | 10:14 AM
Default Re: 2000 cx timing belt question (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
On the flipside, you can probably pick up an entire Y7 head for like 100 bucks.</TD></TR></TABLE>
True, i didnt take into account the fact that anyone probably would have tried to start it back up once it died which would have done some damage.
The reason i said he probably was (should have said "might be") is i've seen a belt snap while trying to start and it was ok, also a timing belt on an LS skip about 10 teeth on start up and be fine.
Old Nov 4, 2007 | 03:50 PM
19slocivic97's Avatar
Are you sure the belt broke? I've seen a numerous 96-00 civics come through work that had cold start flood problems. Do a wet compression test and see what hapens, if comp. comes up install new plugs and hold gas pedal down to clear flood mode..should start..
Old Nov 4, 2007 | 03:58 PM
t0p_sh0tta's Avatar
Default Re: 2000 cx timing belt question (19slocivic97)
Easy way to see if the belt broke is to have someone try to start while you remove the oil cap and see if the rockers are moving.
Old Nov 4, 2007 | 04:38 PM
boomnn's Avatar
well i definetly tried to start it after it died which was immediately. when i tried to re-start it the starter and motor sounded like it was spinning really fast and very easily instead of the usuall sound. if the belt broke and i didnt bend a valve but kept tring to start it the valves wouldnt move right, but if one of them was down it would just beat the **** out of it.
well if anyone has a head for sale looks like im probably looking for one now...
Old Nov 4, 2007 | 06:03 PM
vrrodri's Avatar
If you noted the sputtering and the engine not turning right, then yes it broke the belt and you have damage...
Old Nov 6, 2007 | 04:29 PM
It may sound like the motor is turning over fast because it may have washed the rings with fuel.. This why you need to do a wet compression test!
contractkiller
Feb 5, 2008 10:43 AM
siplaya
Feb 2, 2007 08:35 AM
ThePunk
Jan 18, 2007 01:46 AM
2000CivicSiLasVegas
May 17, 2004 09:34 PM
civicracer1993
Feb 28, 2003 05:23 AM
