Redline problem ! help out please !
Old Jun 22, 2002 | 10:28 PM
superslowhatch's Avatar
Default Redline problem ! help out please !
Hi guys !
I just done swap B17a1 to my 93 Si. I'm using 93 Gs-R ECU , vtec kicked fine but there's little problem about red line. On the Si cluster's redline was 7200 rpm, but when I redline , the fuel cut off at 6800 rpm, why is that ? When I used to have my 93 gs-r, same ECU and I redline up to 8200 rpm . Is anyone know how is this happened ?
Old Jun 22, 2002 | 10:30 PM
KoRE's Avatar
Default Re: Redline problem ! help out please ! (superslowhatch)
maybe tach is off my teg i thoguh it would cut off at 8k but then when i put the afc in it showed 7k something where fuel would cut off so it might be the tach
Old Jun 22, 2002 | 10:54 PM
Vanilla4215's Avatar
Default Re: Redline problem ! help out please ! (KoRE)
check your miles per hour at the cut off. If the tach is wrong you should still be at about 40 mph by the end of first. I don't know the exact mph for your tranny, but if someone else knows go ahead and post.
95b18c1egcoupe
May 6, 2013 12:57 PM
WhiteGSR95
Mar 29, 2005 08:11 AM
racedoutsi
Mar 31, 2002 06:41 PM
