help me out...want more power out of k20a2.
Old Nov 4, 2007 | 08:52 AM
BMRALR's Avatar
Default help me out...want more power out of k20a2.
Need some tips...I want 230-260 whp out of a k20a2 but no turbo...NA. Besides kpro/e/i/h cams....what else could buy to achieve this? What exhaust is a suttle,quite exhaust for k20a2 swapped in a ek chassis. Also dont know which cams to buy, Searched and found Brian krower are these too aggressive? thanks..any info will help.
Old Nov 4, 2007 | 08:56 AM
Luserkid's Avatar
Default Re: help me out...want more power out of k20a2. (BMRALR)
Bump compression and youll get your goal.
Old Nov 4, 2007 | 10:38 AM
BMRALR's Avatar
Default Re: help me out...want more power out of k20a2. (Luserkid)
what does the 5.062 final drive actually do for the k20a2? Is it worth it? Is it true that you have to buy a bearing part because im running the stock 4.4 final drive? thanksss
Old Nov 4, 2007 | 10:44 AM
cartune network's Avatar
putting a final drive in isnt a bad idea. the final drive will make your gears shorter and youll shift sooner. not a bad thing but its not gonna give you horsepower. i would say get some rods and pistons and a good set of cams.
Old Nov 4, 2007 | 10:46 AM
BMRALR's Avatar
Default Re: help me out...want more power out of k20a2. (cartune network)
this is a street driven car not track car..should i do the 5.062 final drive for a street car or leave the stock final drive? Also, should i buy stage 2 hasport axels or stage 1 will be fine? hmotorsonline.com charges 300 extra for axels thats where i will buy them most likely unless i need stage 2???
Old Nov 4, 2007 | 10:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMRALR &raquo;</TD></TR><TR><TD CLASS="quote">this is a street driven car not track car..should i do the 5.062 final drive for a street car or leave the stock final drive? Also, should i buy stage 2 hasport axels or stage 1 will be fine? hmotorsonline.com charges 300 extra for axels thats where i will buy them most likely unless i need stage 2???</TD></TR></TABLE>
a 5.062 final isnt bad for street. im curious as to where you even found a 5.062. because the only ones i have found were 5.6x or 6.xx+.
the axles are up to you. there is a big price difference between the stage 1 axle and the stage 2 axle. stage 1's should do the job.
Old Nov 4, 2007 | 10:57 AM
BMRALR's Avatar
found the 5.062 final drive at hmotorsonline.com whats wrong with the 5.062???
Will the AEM k series swap into ek chassis bolt up to RBC intake manifold?
Old Nov 4, 2007 | 11:06 AM
Lordofdark176's Avatar
wow you dont know anything about your swap do you. im not trying to be a dick or anything but do some research, then ask questions to stuff you couldnt find answers to.
Old Nov 4, 2007 | 11:10 AM
nothing is wrong with the 5.06x final drive. its up to you wether or not you want it. i would get i but then again i dialy a 4.9 final in an itr tranny so my vote is biased.
BMRALR's Avatar
Default Re: (Lordofdark176)
thanks for helpin a guy in need out...
Old Nov 4, 2007 | 11:25 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (BMRALR)
IPS KME or K2 cams and valvetrain coupled with any decent intake/header/exhaust combo and K-Pro tuning will get you there. That's really the only way to achieve your goal without forced induction or nitrous. You can bump the compression, but that alone won't do it. Without the cams, you're just whistling dixie, and with them you won't need the huge bump in compression.
Do some research and stop wasting our time.
Old Nov 4, 2007 | 12:28 PM
BMRALR's Avatar
Default Re: (Archidictus)
yeah thanks. if i get the evolution industries ac/ps remvoal kit do i need to buy all the idler pulley parts??
Old Nov 4, 2007 | 01:56 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BMRALR &raquo;</TD></TR><TR><TD CLASS="quote">yeah thanks. if i get the evolution industries ac/ps remvoal kit do i need to buy all the idler pulley parts??</TD></TR></TABLE>
I don't know. Why don't you have a moderator move this to the RSX/EP forum so people with this engine can actually help you?
Old Nov 4, 2007 | 06:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">IPS KME or K2 cams and valvetrain coupled with any decent intake/header/exhaust combo and K-Pro tuning will get you there. That's really the only way to achieve your goal without forced induction or nitrous. You can bump the compression, but that alone won't do it. Without the cams, you're just whistling dixie, and with them you won't need the huge bump in compression.
Do some research and stop wasting our time.</TD></TR></TABLE>
wtf are you talking about? big cams will do nothing for you unless you have the compression for them to use. You have to bump the compression up to get the best out of any bigger cam.
Old Nov 4, 2007 | 06:42 PM
.I.Need.Money.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lordofdark176 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf are you talking about? big cams will do nothing for you unless you have the compression for them to use. You have to bump the compression up to get the best out of any bigger cam.</TD></TR></TABLE>
The K20A2 has good enough compression for fairly large cams.
b00stedbyFastrax
Sep 4, 2008 08:47 AM
RagingAngel
Mar 4, 2005 08:01 AM
JDM_Type-R
Sep 16, 2003 08:45 AM
Turbo Powa
Mar 27, 2002 04:47 PM
