Center Bore
Old Nov 4, 2007 | 08:16 AM
baiwldrnner's Avatar
Default Center Bore
Does anybody know the center bore for 15" Rota Torque wheels? I'm in the market of buying center caps. Thanx.
Old Nov 4, 2007 | 08:22 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Center Bore (baiwldrnner)
The center bore is not necessarily the diameter of where the center caps mount. So that information won't help you.
For example, the '91-01 NSX has wheels with different center bores, front vs rear. One is 64 mm, the other is 70 mm. But the wheels at both ends use the same center caps. (And, in fact, the diameter of the center caps for the '91-93 wheels, at both ends, is different from the diameter of the center caps for the '94-01 wheels.)
Old Nov 4, 2007 | 09:17 AM
Default Re: Center Bore (nsxtasy)
Ohh opps, ok, my bad. I just read what center bore is .
So....then what spec of the wheel is needed to determine the size of the center cap? I assume u can't just slap on any cap onto a wheel.
Old Nov 4, 2007 | 09:39 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baiwldrnner &raquo;</TD></TR><TR><TD CLASS="quote">what spec of the wheel is needed to determine the size of the center cap? I assume u can't just slap on any cap onto a wheel. </TD></TR></TABLE>
You could measure the diameter of where the center cap fits. But that number is not usually included in the wheel specs. You usually have to ask whether such-and-such center cap fits.
Old Nov 4, 2007 | 10:03 AM
Cool, Thanx for ur help
TracerAcer2.2L
Feb 26, 2018 08:00 PM
jrscb16eg6
Wheels
Oct 29, 2009 10:39 AM
mikeycivic
Jun 19, 2008 01:11 PM
HOMESLICE
May 18, 2005 08:08 AM
dLo GSR-stolen-now-WRX
May 18, 2002 12:48 PM
