4x100 Advan center caps?
Anti-GDD White Knight Simp
Why does Advan apparently only have center caps for 5x100 and 5x114.3 wheels? And I can't find any used caps for 4x100, either, although it seems like they should have made them at some point since 4x100 used to sell like wildfire.
Would the 5x100 caps fit since both PCDs are "100"?
Sanji
Re: 4x100 Advan center caps?
You didn't really mention what model Advan you're referring to. Different caps were available, depending on model.
But, as far as the hub bore is concerned, some of their designs the bolt circle will dictate the hub bore size... some will not. Just because its 5x100, doesn't necessarily mean that it'll have the same bore diameter as the 4x100 model.
Sorry, I didn't mention the specific wheel because on their site they just have caps that fit either all 5x100, or all 5x114.3, leading me to believe that all of their wheels of that PCD have the same bore.
Specifically, I just got the RG II in 4x100, and would love to be able to use the completely flat center caps if possible
Thanks for your help Matt!
