please help! erything went wrong!
i tried to install the pioneer d3 into my 08 civic si, i have no sound / my passive alarm now wont work / power locks wont work unless the key is in the ignition / interior lights wont light up when the door opens / and the yellow wire which is supposed to have constant power doest have any at all . i think it may be a fuse but if anyone can throw any ideas please help.
wow...thank sucks man. hope everything is fixed.
definitely let the pro's deal with navigation. headunits are one thing...navi's are a completely different thing in my experience.
there's one fuse you should check under the hood. It has a name that you wouldn't think to check. I believe it has a 15amp fuse. check that.
EDIT: what harness do you have? The Scosche harness is F'ed up, two wires are switched up (wrong color)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 08CivicSi »</TD></TR><TR><TD CLASS="quote">i tried to install the pioneer d3 into my 08 civic si, i have no sound / my passive alarm now wont work / power locks wont work unless the key is in the ignition / interior lights wont light up when the door opens / and the yellow wire which is supposed to have constant power doest have any at all . i think it may be a fuse but if anyone can throw any ideas please help.
sounds like a fuse, but might be a little more than that. looks like you might be paying someone to troubleshoot your mess
first thing you need to tell us is which wire(s) you touched
</TD></TR></TABLE>sounds like a fuse, but might be a little more than that. looks like you might be paying someone to troubleshoot your mess
