Honda S2000 Honda S2000
*Problem with missfireing*
Old Nov 3, 2007 | 05:45 PM
6KVtec's Avatar
Default *Problem with missfireing*
ok so my check engine light is still on...so i got the codes pulled and the codes its pulling is 302, and 1399...now i know that the 302 is missfire in the second cylinder, but what exactly is the 1399?...now it is a 2001 AP1, i have replaced my sparkplugs with in the past month...i have checked the coils and they are not cracked...this has been going on for some time...im getting sick and tire of driving around in a 20k car and having a dam check engine light on...and today i just noticed that my maintenance required lights blinks before i start it...so ya, any help is great! thanks!
Old Nov 3, 2007 | 08:47 PM
GearShifter's Avatar
Default Re: *Problem with missfireing* (6KVtec)
timing?
Old Nov 3, 2007 | 09:53 PM
pepper's Avatar
try adjusting the valves for that misfire, we had two crv and a s2k that came in with a misfire code, so my boss adjust the valves for them and they never came back with the same problem.
Old Nov 3, 2007 | 10:53 PM
6KVtec's Avatar
Default Re: (pepper)
oh ya, sorry boss...the valves have been adjusted i forgott to put that...but here is the thing, before when i took it into this one shop it was saying that all 4 cylinders were missfireing...and after staying at that shop from 2pm to 3am when i left the code it was pulling was one that said my secondary air pump was bad...but that works just fine because when i turn the car on in the morning you can hear it...and now its reading a 302, and 1399 both of wich have nothing to do with the secondary air pump...its just missfireing again and i dont know how.....
Old Nov 4, 2007 | 06:27 PM
6KVtec's Avatar
Default Re: (6KVtec)
and i have also had the timeing checked...and it was good.
Old Nov 4, 2007 | 07:20 PM
OutLaw MR's Avatar
swap ignition coils/injectors with another cylinder...recheck
Old Nov 4, 2007 | 07:33 PM
jeffhaut's Avatar
Default Re: (OutLaw MR)
up in canada we have an update for spark plugs with a stainless crush ring, im not sure if it applies to you folks in the states but its worth it to ask the dealership.
basically the aluminum crush rings on standard ngk plugs dont allow for enough torque so the plugs can work themself a tiny bit loose, so honda released a plus with a tougher ring that you need to torque down a bit more
Old Nov 4, 2007 | 08:14 PM
6KVtec's Avatar
good idea, i have not tried that yet...i will mark them and then swap them and find out...a different spark plug you say? well it looks like im going to be calling the dealership in the morning to find out, thanks guys...anyone else with more thoughts please let me know. thanks!
Old Nov 5, 2007 | 07:45 AM
Nishant's Avatar
I had a misfiring problem before. I would check the spark plugs/coils first. Then the injectors. Mine turned out to be a bad injector
Old Nov 5, 2007 | 07:16 PM
CNSK's Avatar
Default Re: (Mr. Nishant)
I have the same problem as we speak. Misfire on cylinder 1 and 4 from honda diagnotic. Honda Service guy told me that my 1 and 4 compression is reading 140 and should be at 220-230. He told me that I may have blown piston ring,head gasket or bent valves. Now I just gotta fight with the dealership from the place that I bought it from(non honda) and hope they will pay for my damages to the motor. I've only had the car for a week and should still be under warrenty(30 day 1,000 miles) plus I bought the extended warranty for 3yr 36k. I hope everything goes smoothly but its gonna be a bitch fighting with the dealer to pay for it. I wonder if there gonna give me a new short block??? Anyways you may wanna shoot a compression test and see. I'll keep you posted on any updates I have and give you a list of my damages. My car may be in the shop for a few week.
My symptoms are: motor sputters hesitates, exhaust stinks, small whistling sound, sometimes hard to start.
Old Nov 6, 2007 | 12:27 AM
6KVtec's Avatar
Default Re: (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem as we speak. Misfire on cylinder 1 and 4 from honda diagnotic. Honda Service guy told me that my 1 and 4 compression is reading 140 and should be at 220-230. He told me that I may have blown piston ring,head gasket or bent valves. Now I just gotta fight with the dealership from the place that I bought it from(non honda) and hope they will pay for my damages to the motor. I've only had the car for a week and should still be under warrenty(30 day 1,000 miles) plus I bought the extended warranty for 3yr 36k. I hope everything goes smoothly but its gonna be a bitch fighting with the dealer to pay for it. I wonder if there gonna give me a new short block??? Anyways you may wanna shoot a compression test and see. I'll keep you posted on any updates I have and give you a list of my damages. My car may be in the shop for a few week.
</TD></TR></TABLE> see and thats just it...i have had the compression tested...and the injectors tested...i had it ran through this system that does a complete motor flush..it runs through the whole fuel system and checks everything..and my injectors came back good...but i mean it starts/runs just fine, you would never know it was bad with out that engine light...i mean you can hear the missfire when at idol, but thats it...my exhaust smells just fine, its not running rich or lean...im so dam stumped its not even funny! all i want is to get this fixed after owning the dam thing almost 3 months! pfft so irratating
Old Nov 6, 2007 | 06:43 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
just throwing it out there....
positive theres 91oct in the tank???
Old Nov 6, 2007 | 12:35 PM
6KVtec's Avatar
Default Re: (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">just throwing it out there....
positive theres 91oct in the tank??? </TD></TR></TABLE>
no worries...i have never put anything else in it...and nothing besides chevron gas either.
Old Nov 6, 2007 | 12:40 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
is the car burning any oil ???? no exhaust leak off the header to head flange that the intake is taking in......
spark plug gaps?
is it still on the same tank of gas that this started on?
pull the VC and check the valvetrain
Old Nov 6, 2007 | 12:47 PM
6KVtec's Avatar
nope..no oil being burned...no exhaust leak...spark plugs dont need to be gapped...and no im on like the 59949395 tank of gas...stupid 23MPG! and when i had the valves adjusted he looked at the valvetrain and made sure it was good.
Old Nov 6, 2007 | 12:51 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
without looking at it i would tell you to reset the ECU completely... pull the battery for 15mins to ensure its reset and hope for the best...
maybe you need some seafoam in that bitch...
Old Nov 6, 2007 | 12:53 PM
6KVtec's Avatar
yes yes i have pulled the battery i have let it sit for almost a half hour countless times. Seafoam?? what be that?
Old Nov 6, 2007 | 04:08 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
the seaform will clean out the inside of the motor.....
do a leakdown and then we can go from there
Old Nov 6, 2007 | 04:14 PM
6KVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">the seaform will clean out the inside of the motor.....
do a leakdown and then we can go from there</TD></TR></TABLE>
sounds like a plan boss, but what is a leakdown?
Old Nov 6, 2007 | 09:55 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6KVtec &raquo;</TD></TR><TR><TD CLASS="quote">
sounds like a plan boss, but what is a leakdown?</TD></TR></TABLE>
you % your lost within the cylinder to get an idea to what is wrong, valves, seals,rings etc....
Old Nov 6, 2007 | 10:32 PM
6KVtec's Avatar
you % your lost within the cylinder to get an idea to what is wrong, valves, seals,rings etc....</TD></TR></TABLE>
ok, and i how do i accomplish that??
Old Nov 8, 2007 | 02:37 PM
6KVtec's Avatar
well everyone i thank you for all your suggestions and ideas...but nothing is working and so i dont do any further damage i think im just going to have to take it to a dealer, but once again thanks for all your help!
SEA ARE EX
20
Jan 10, 2012 05:30 AM
Allrice
Jan 16, 2011 01:23 PM
Snail EK
Jun 27, 2004 11:07 PM
UKPRELUDE
May 17, 2004 08:03 AM
KAM1977
Jan 7, 2003 10:59 AM
