Wiring VTEC Oil Pressure Switch Quick Question
Old Nov 3, 2007 | 04:46 PM
SiRTifiedacc's Avatar
Default Wiring VTEC Oil Pressure Switch Quick Question
The colors of the wires are just for reference and are just a miscellaneous plug identical to the VTEC OPS plug.. (between the red or the blue wire) can any one tell me which one is the ground and which one runs to the ECU?
Modified by SiRTifiedacc at 6:00 PM 11/3/2007
Old Nov 3, 2007 | 04:51 PM
zerovandez's Avatar
http://technet.ff-squad.com/wiring.obd2a.htm
Old Nov 3, 2007 | 05:01 PM
Default Re: (zerovandez)
yes im aware of all that... its still not helping whether the top pin or bottom pin is goes to the ecu
Old Nov 3, 2007 | 05:12 PM
ekb16's Avatar
i dont think it really matters which one is ground or ecu..i would bring the red to the ecu and blue to ground
Old Nov 3, 2007 | 05:24 PM
Default Re: (ekb16)
thanks... anyone else?
Old Nov 4, 2007 | 06:15 AM
Default Re: Wiring VTEC Oil Pressure Switch Quick Question (SiRTifiedacc)
UP
Old Nov 5, 2007 | 05:27 AM
anyone?
Old Nov 5, 2007 | 09:41 AM
zerovandez's Avatar
run your red to the ecu. ground the blue.
Old Nov 5, 2007 | 10:07 AM
thanks mang
Old Nov 5, 2007 | 10:38 AM
fmrprojects's Avatar
Default Re: (SiRTifiedacc)
the one closes to the clip of the plug is to the ecu and the other is ground
Old Nov 5, 2007 | 02:25 PM
Default Re: (fmrprojects)
great thanks! thats 2 for 0.
Old Nov 5, 2007 | 02:43 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">run your red to the ecu. ground the blue.</TD></TR></TABLE>
Or run the blue to the ecu and the red to ground, because it doesn't make any difference. It's just a switch input.
trickster kid
Aug 25, 2009 05:52 PM
EGB18C
Feb 2, 2006 02:57 PM
crxh22project
Jan 25, 2005 10:46 AM
Civic Hx-T
May 12, 2004 09:21 AM
