Gains in chipping built D16a6 ...
Old Jun 22, 2002 | 08:50 PM
89 CRX SI's Avatar
Default Gains in chipping built D16a6 ...
I got a 89 CRX Si. Im building a D16a6 for it. What gains should i expect from chipping a 90 ECu for it?
What should i ask him to do .????????
He will do it for 150 cdn....
Old Jun 22, 2002 | 09:06 PM
89 CRX SI's Avatar
Default Re: Gains in chipping built D16a6 ... (89 CRX SI)
man nobody one this board but lie 10 people know D series stufff
Old Jun 22, 2002 | 11:01 PM
CRXSleeper's Avatar
Well i have a chipped ECU on my D16a6 and i couldn't tell a difference. I think it's one of those mods in which the more engine work you have done, the more beneficial it will be, but since i only have the basic bolt ons, i can't tell a difference. I think all a chipped ECU mostly does is change the rev limiter so it can rev higher and also change the fuel mixture so more fuel burns. I think that's about it. My rev limiter is now set at 8000 rpm, but i hardly ever take it that high cause it just doesn't sound right with my stock engine. I think it will snap any moment. I keep it at the stock level of 6500 or below.
Old Jun 23, 2002 | 12:42 AM
shortyz's Avatar
Default Re: Gains in chipping built D16a6 ... (CRXSleeper)
wuss
Old Jun 23, 2002 | 09:07 AM
Malgerus's Avatar
Default Re: Gains in chipping built D16a6 ... (shortyz)
wuss
How many motors have you blown up?
Old Jun 23, 2002 | 09:19 AM
ZColeon's Avatar
New User
your going about this at the wrong direction. Low compression high compression, what are you gonna do, chip an ecu, why you had someone re grind your cam? that would be the first thing, your lobe and duration= max volume pending flow in retrospec to what your head can do. Really be serious about this, contact Darton sleeves, do a mad bore, Push a stock head norm. compression, port intake / head, then (easiest for you ) buy a gude steup, and a homemade turbo.. just my thoughts
Old Jun 23, 2002 | 09:21 AM
ZColeon's Avatar
New User
Default Re: Gains in chipping built D16a6 ... (89_Y_49)
or how many bearing have you spun, the limiter is there for a reason, You'd understand that if you had a value of your own money, not your mommas....
Jay.D.Em!
12
Feb 9, 2006 03:41 PM
IA95civicDX
13
Oct 25, 2005 05:10 PM
superbeastcrx
Sep 17, 2005 07:20 AM
AkEuro_R
Apr 27, 2004 04:00 PM
USDM 4G VTEC
11
Aug 16, 2002 12:12 PM
