fs: rear discs/misc civic stuff
selling a set of rear discs off a del sol....everything is there : trailing arms, calipers, e-brake cables (del sol), upper control arms.
also including a set of earl's stainless brake lines (all four), 2 qts of ATE super blue fluid (dot 4) and a 4040 prop valve.
brake assembly's : $150
lines/fluid : $120
prop valve : $40
or everything for $300
and i also have...
- 94+ integra full length radiator. good shape, a few bent fins. comes with a fan. $40 obo
- stock z6 cam/gear $10 obo
- misc mounts/brackets for d-series. just ask and i'll check.
- any odd/end off a d-series (ps pump, alternator, etc.). pm me and i'll give you a price.
- black 92-95 driver and passenger airbags. good shape, no scuffs/damage. $50 each
- stock 93-95 coupe tailights. $20 OBO
- gray coupe/hatch drivers side a-pillar interior piece. $10 OBO
- gauge cluster bezel. no clock/block off plate. $15 OBO
- eg climate control. $25 OBO
- any switch on an ex (mirrors/dimmer/sunroof/cruise) $5 each
-beaks lower tie bar. DESTROYED
-gsr rear sway bar. bar, mounting brackets/bushings and endlinks are included. PENDING
-buddly club voltage stablilizer/ground kit. great shape. crappy pic, but everything is there and none of the wires are cut/shortened $75
-megan racing h-brace. SOLD
EVERYTHING IS OBO AND SHIPPING IS NOT INCLUDED!
Modified by SOHCejcivic at 8:00 PM 11/16/2007
Modified by SOHCejcivic at 8:01 PM 11/16/2007
lines/fluid : $120
prop valve : $40
and i also have...
Fiero
Mar 23, 2008 06:39 PM
