Correct Tire Pressure
Old Nov 3, 2007 | 01:07 PM
Importn2oRacer's Avatar
Default Correct Tire Pressure
What should be a good PSI for all four tires on my 2000 Accord 4 cylinder?
Old Nov 3, 2007 | 01:30 PM
cb1999nj's Avatar
Default Re: Correct Tire Pressure (Importn2oRacer)
Look inside your driver or passenger side door... there should be a tag on your doorjamb saying what the correct psi for your car is.... it's called the vehicle information placard....
Each car is different.... here's an article:
http://www.betiresmart.ca/infl...acard
Old Nov 3, 2007 | 04:38 PM
defaced8's Avatar
Default Re: Correct Tire Pressure (cb1999nj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb1999nj &raquo;</TD></TR><TR><TD CLASS="quote">Look inside your driver or passenger side door... there should be a tag on your doorjamb saying what the correct psi for your car is.... it's called the vehicle information placard....
http://www.betiresmart.ca/infl...acard</TD></TR></TABLE>
It should be around 32-35psi. Shouldn't be any more or any less. On my 97 it recommends 32 but I usually keep around 35 in my tires. Not that big of a difference in 3psi. Although, when mine are at 30-32, the front always look damn near flat.
Old Nov 3, 2007 | 04:54 PM
Chiovnidca's Avatar
32 I believe is what honda recommends. What they suggest is for the best mix of preformance, ride quality, and tire wear. You can adjust them to suit you if you want.
Old Nov 4, 2007 | 06:45 AM
Tyte-S's Avatar
Default Re: Correct Tire Pressure (Chiovnidca)
Matters what tires you have. I have a set of Falkens on my 6th gen Accord, and it states to never exceed 41PSI. Usually staying between 32-37PSI, you will be pretty safe. It will say in your tires though what the recommended PSI is.
Old Nov 4, 2007 | 06:47 AM
Chiovnidca's Avatar
Default Re: Correct Tire Pressure (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote"> It will say in your tires though what the recommended PSI is.</TD></TR></TABLE>
Nope, it will say on your tires what the maximum psi is.
Old Nov 4, 2007 | 12:10 PM
Tyte-S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, it will say on your tires what the maximum psi is.</TD></TR></TABLE>
Old Nov 4, 2007 | 04:54 PM
JimBlake's Avatar
Chio is CORRECT once again.
Old Nov 4, 2007 | 05:58 PM
Chiovnidca's Avatar
Default Re: Correct Tire Pressure (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
heeeeee
grpape
16
May 14, 2009 10:24 AM
dubnine
Sep 2, 2008 08:11 PM
RACEPAK
Jul 12, 2008 04:27 PM
BDogggUT34
Nov 28, 2005 10:39 AM
free4frank
Jul 6, 2005 07:43 PM
