Suspension & Brakes Theory, alignment, spring rates....
Opinions on Suspension Technique Rear Sway on a EG - Also fitment question
Old Nov 3, 2007 | 11:20 AM
vestalfootball72
Guest
Posts: n/a
Default Opinions on Suspension Technique Rear Sway on a EG - Also fitment question
Hey guys- Im looking to do my next suspension upgrade, and money is getting tight. I figure that a rear sway is the best thing to do- I have a 1994 Honda Civic SI non abs- I want to avoid putting on aftermarket LCA's, and insead use a suspension technique rear sway bar kit-
This kit right here is everything I need is it not?
http://store.summitracing.com/...w=sku
(anyone know of a cheaper place to pick it up?)
Also what are your opinions on it?
thanks guys
Old Nov 3, 2007 | 02:15 PM
mormonboy's Avatar
Default Re: Opinions on Suspension Technique Rear Sway on a EG - Also fitment question (vestalfootball72)
May i recommend you going with an OEM itr sway kit. can't go wrong with oem.
Old Nov 3, 2007 | 03:12 PM
vestalfootball72
Guest
Posts: n/a
Default Re: Opinions on Suspension Technique Rear Sway on a EG - Also fitment question (mormonboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mormonboy &raquo;</TD></TR><TR><TD CLASS="quote">May i recommend you going with an OEM itr sway kit. can't go wrong with oem. </TD></TR></TABLE>
I dont want to upgrade my LCA's
Old Nov 3, 2007 | 07:50 PM
mormonboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">
I dont want to upgrade my LCA's</TD></TR></TABLE>
why would you need to?
Old Nov 3, 2007 | 07:56 PM
vestalfootball72
Guest
Posts: n/a
why would you need to? </TD></TR></TABLE>
Where would the ITR sway hook to? its my assumption that there made to hook to the LCA...
jredhonn
Suspension & Brakes
Dec 26, 2007 05:34 PM
projectTeG
Suspension & Brakes
Jan 18, 2007 03:03 AM
VTECR021
46
May 8, 2004 07:44 PM
gsrpilot8000
Aug 11, 2002 07:07 PM
memphiss13
May 30, 2002 06:38 PM
