jdm ignition harness?!?
Old Nov 3, 2007 | 10:38 AM
mini-meEj1's Avatar
Default jdm ignition harness?!?
is the jdm itr ignition harness sopposed to turn all the lights on the gauge cluster when you turn it to number one spot..i don't know if this is sopposed to be like this my friend said it might but i want to know for sure
Old Nov 3, 2007 | 11:16 AM
mini-meEj1's Avatar
Default Re: jdm ignition harness?!? (mini-meEj1)
bump for help
Old Nov 3, 2007 | 12:07 PM
mini-meEj1's Avatar
bump bump bump
Old Nov 3, 2007 | 12:17 PM
BlueIntegraBoy's Avatar
It should be like any other ignition harness where only the radio comes on in the 1st position (ACC). The lights don't come on until the 2nd position (IGN).
Old Nov 3, 2007 | 12:38 PM
mini-meEj1's Avatar
Default Re: jdm ignition harness?!? (BlueIntegraBoy)
well do you have any idea as to what it could be? i mean i wired it up right (plug in) and when i turn it to the number one spot the fuel pump kicks on. should i really be to worried bout this because it's turning over in the right spot it just that little defect
Old Nov 3, 2007 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-meEj1 &raquo;</TD></TR><TR><TD CLASS="quote">well do you have any idea as to what it could be? i mean i wired it up right (plug in) and when i turn it to the number one spot the fuel pump kicks on. should i really be to worried bout this because it's turning over in the right spot it just that little defect </TD></TR></TABLE>
I don't really see a problem.
Old Nov 3, 2007 | 07:15 PM
mini-meEj1's Avatar
ok i was just makin sure that it wasn't anything serous thanx for the help
kyleb18t
Dec 28, 2008 08:48 PM
vietnamezerice
May 31, 2008 10:18 PM
$ISELLTOU4LESS$
Nov 27, 2006 08:12 AM
latindc2
Dec 7, 2005 09:18 AM
hotimportcrx
13
Oct 23, 2005 08:46 PM
