2000 Prelude 75shot zex wet kit little help
First post here so here it goes.
My setup
2000 prelude base
I/H/E/
Tuned VAFC (Running Rich while on Nitrous for Safety)
ACT clutch and lightened flywheel
MSD SCI Ignition w/ blaster 2 and wires
Zex Spark Plugs
Zex Wet kit currently running 55 shot about 6 bottles in a couple years no problem
Dynotune bottle heater
Also before I added the 55 shot a couple years ago had a compression test done and 3 angle valve job done.
What I'm doing
want to increase to the 75 shot with the zex kit
got msd 8982 start/retard controller to retard timing 3 deg while on the juice
got msd 8969 digital rpm window switch to keep traction and cut of juice before the rev limiter
Wondering what the opinions are about how safe this will be and any other suggestions I should use to increase my odds of success. This is a daily driver and my baby, I just want more power safely.
If I had the extra money I would upgrade the fuel system, but from what I hear that is not necessary with the ludes until 100 shot.
Will probobly get a fuel safety switch and new high flow fuel pump as well as FPR to beef up my fuel system.
Thanks in Advance
Modified by silverlude80 at 9:26 AM 11/3/2007
Modified by silverlude80 at 9:35 AM 11/3/2007
My setup
2000 prelude base
I/H/E/
Zex Spark Plugs
What I'm doing
Thanks in Advance
