Weather kits
It is high time I fixed the weather stripping on my Rex. I am needing the doors seals, window seals, trunk seals, roof strips... everything. Is there any place that sells kits with all the stripping needed? I see dealerships sell each piece, but I'm wanting all of it. My Rex needs it bad.
Modified by REX_in_TEX at 8:37 AM 11/3/2007
well, if you really want to fix it , and have it seal good, get it from honda. if there are aftermarket seals available, i'd bet they dont fit well or seal as good.
start saving up, or buy them one section at a time. do you really need all those seals? maybe you could check each seal with a hose and a buddy inside looking for leaks, that way you can narrow it down to which seals are really bad.
