good exhaust
Old Nov 3, 2007 | 06:11 AM
zcrx2006's Avatar
Default good exhaust
what is a good exhaust setup for a boosted d series? thanks
Old Nov 3, 2007 | 06:20 AM
blitz23's Avatar
Default Re: good exhaust (zcrx2006)
min 2.5 inch turbo back (bought off the shelf or custom made) and if you need it to pass smog put high flow cat in the middle of it.
Old Nov 3, 2007 | 07:48 AM
95jeremie's Avatar
what i have on my car is what i would suggest if you looking for low #'s as far as you power levels go.I'm only going to be around 220-230 and i wanted to keep a stock look and a good clean stock sound (no bumble bee exhaust for me plz.) It's a 2.5 inch high flow magna flow cat, a 2.5"x18" resonator also magna flow, and an oval turbo exhaust that has a center inlet 2.5" and an offset output 2.5". all with 2.5" mandrel bent pipping. still looks stock sounds great and flows good enough for my goals. however i will probably get a bolt in test pipe set up so that way i can switch it out. not only that but you can make a regular pipe look like a cat fairly easy. but i don't have to stress that where i live.
Old Nov 3, 2007 | 08:58 AM
Topdawgg's Avatar
to make the power easier, go with 3 inch
Old Nov 3, 2007 | 09:40 AM
Schister66's Avatar
Man U FTW
just go with 3" because 9 times out of 10, you'll never have to go bigger
Old Nov 3, 2007 | 05:59 PM
95jeremie's Avatar
Default Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">to make the power easier, go with 3 inch</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">just go with 3" because 9 times out of 10, you'll never have to go bigger</TD></TR></TABLE>
true it just depends on what you want from your car . i prefer the stock looking sleeper. if you don't care how it looks definitely go 3". i know that one day i will redo it and go 3" but that is years away. right now my wallet and parts can only do so much. o ya and this is my daily driver as well so i like to keep the low profile.
Old Nov 4, 2007 | 06:35 AM
Topdawgg's Avatar
Default Re: (95jeremie)
my 3 inch fits better then a stock exhaust... lol
S2KILLA
Jul 25, 2006 12:33 PM
escape2me
Feb 19, 2005 10:55 AM
JDMCRX
Mar 29, 2004 12:26 PM
2000GSRT
Jun 25, 2003 09:56 AM
