good exhaust
what i have on my car is what i would suggest if you looking for low #'s as far as you power levels go.I'm only going to be around 220-230 and i wanted to keep a stock look and a good clean stock sound (no bumble bee exhaust for me plz.) It's a 2.5 inch high flow magna flow cat, a 2.5"x18" resonator also magna flow, and an oval turbo exhaust that has a center inlet 2.5" and an offset output 2.5". all with 2.5" mandrel bent pipping. still looks stock sounds great and flows good enough for my goals. however i will probably get a bolt in test pipe set up so that way i can switch it out. not only that but you can make a regular pipe look like a cat fairly easy. but i don't have to stress that where i live.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">to make the power easier, go with 3 inch</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">just go with 3" because 9 times out of 10, you'll never have to go bigger</TD></TR></TABLE>
true it just depends on what you want from your car . i prefer the stock looking sleeper. if you don't care how it looks definitely go 3". i know that one day i will redo it and go 3" but that is years away. right now my wallet and parts can only do so much. o ya and this is my daily driver as well so i like to keep the low profile.
JDMCRX
Mar 29, 2004 12:26 PM
