post your self etching primer.(army green) car.
Old Nov 2, 2007 | 06:45 PM
mustang5.slow's Avatar
* B A N N E D *
Default post your self etching primer.(army green) car.
here is mine. i love this color.
the only down side is that the sun turns it brownish on some spots.
Old Nov 2, 2007 | 07:20 PM
Capt. Jimbo McSubipants's Avatar
Default Re: post your self etching primer.(army green) car. (mustang5.slow)
looks nice but as with any primer job id say it can get old pretty quick...
Old Nov 2, 2007 | 07:22 PM
* B A N N E D *
Default Re: post your self etching primer.(army green) car. (CW-R hatchback)
yeah that sucks that is why i carry a can with me at all times.lol
Old Nov 5, 2007 | 11:50 AM
CBURKE's Avatar
Also primer will suck in water and you can get rust under there and never know it untill you get a hole.
Old Nov 6, 2007 | 06:40 AM
chairwitharmrests's Avatar
^-----------i thought that isnt a problem with self etching?
Old Nov 6, 2007 | 07:12 AM
CBURKE's Avatar
That only helps stop bar metal from rusting untill you can put on some primer sealer.
Old Nov 6, 2007 | 10:01 AM
alltech_hybrid's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">That only helps stop bar metal from rusting untill you can put on some primer sealer.</TD></TR></TABLE>
THANK YOU.. at least somebody knows what the hell etching primer is for
Old Nov 6, 2007 | 11:15 AM
matmcg's Avatar
hey my car got in an accident so after replacing the parts i needed to make it one colour
i sprayed the whole thing with grey sandable primer
will that suck in water and cause rust ?? and can i spray the rest of the car with a duplicolor spray paint
Old Nov 6, 2007 | 05:30 PM
powerflow's Avatar
Default Re: (matmcg)
Etch primer is used to condition bare metal and provide good chemical adhesion with acid contents. It can be used wet on wet to sealer or base, or as mentioned to temporarily protect bare metal. Epoxy primer is the more durable, longer lasting DTM primer thats good for long projects and sealing/protecting inside panels and hard to reach bare metal areas. Good epoxy can get expensive, the color you guys are referring to is more like epoxy to me. Etch primer is typically white, gray, black but does come in other colors. Might as well just get some cheap flat single stage. Primers are not meant to be exposed to the elements and preform the best when protected with a topcoat.
Old Nov 7, 2007 | 05:12 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
This is a tech forum.
ek9=]
Jul 9, 2008 02:53 PM
Saosinx
Jun 16, 2006 04:51 PM
Moonbus
Oct 8, 2004 01:12 AM
Wimpy.
Jun 18, 2004 12:17 PM
