Suspension & Brakes Theory, alignment, spring rates....
crx---ek suspension compatibility?
Old Nov 2, 2007 | 04:40 PM
92civeg's Avatar
Default crx---ek suspension compatibility?
im trying to find a good set of coilovers and i came across a used but "like new" setup consisting of.....
ground control coilovers
koni yellows
ground control extended top hats
blox rear lower control arms
now my question is, they are currently mounted on a 98 ek hatchback.....will they bolt up to my crx?...its an 89 si
thanks you ......and i did search but ive read mixed awnsers
Old Nov 3, 2007 | 03:13 AM
92civeg's Avatar
Default Re: crx---ek suspension compatibility? (92civeg)
anyone?
Old Nov 3, 2007 | 03:43 PM
Targa250R's Avatar
be professional
The rear lower control arms will not work at all.
The front dampers will require lower mounting forks sourced from a '92-00 Civic/del Sol or '94-01 Integra. The lower mounting forks on the rear dampers are too narrow for the stock CRX bushing - I don't know if it is possible to modify the bushing enough to make it fit, as I've never tried myself. The damper bodies are also longer, so you will gain droop travel and loose compression travel.
The Ground Control upper mounts will work.
You should probably look for a setup specific to your vehicle instead of buying that one.
DarthNemisis
Suspension & Brakes
May 5, 2013 10:02 AM
shailoche
Jul 3, 2009 02:37 PM
Lasse
Suspension & Brakes
Jan 8, 2009 02:59 PM
1990civhatch
Jul 12, 2008 01:00 PM
reedwilcox
Sep 27, 2005 07:03 PM
