Lightest 15 inch Rims for Everyday Use
Old Nov 2, 2007 | 01:31 PM
200TS EC's Avatar
Default Lightest 15 inch Rims for Everyday Use
Can anyone tell me, what would the lightest rims be for everyday use..?
Thanks
Old Nov 2, 2007 | 02:00 PM
r.wright's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (200TS EC)
i like the volk te37. regamasters are pretty light as well.
Old Nov 2, 2007 | 03:36 PM
doubleshotz's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (Opossum Jenkins)
listed by price (high to low)
Volk CE28 = 8 lbs (15x6.5) / 9.1 lbs (15x7)
Volk TE37 = 8.8 lbs(15x6.5)/ 9.2 lbs (15x7)
SSR Competition = 8.8 lbs (15x6.5)/ 9.2 lbs (15x7)
Enkei RPF1 = 9.8 lbs (15x7)
Konig Heliums = 11 lbs (15x6.5)
Rota Slipstreams = 12 lbs (15x6.5) / 12.9 (15x7)
Old Nov 2, 2007 | 03:52 PM
jmai86's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (doubleshotz)
Enkei RPF1's are probably the best bang for your buck outta that list
Old Nov 2, 2007 | 04:39 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200TS EC &raquo;</TD></TR><TR><TD CLASS="quote">Can anyone tell me, what would the lightest rims be for everyday use..?</TD></TR></TABLE>
That's a trick question!
For everyday use, rim weight doesn't matter.
Old Nov 3, 2007 | 04:46 AM
200TS EC's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (nsxtasy)
Well I dont mean everyday use as in evryday...I use my spin werks and VP Lenso's on the Strip, but when I want to take the car out on the road, I want a rim that is lighter than your normal everyday rim.....
thanks for the info guys!
Old Nov 4, 2007 | 05:57 AM
problem_si's Avatar
Falken hannabi in 15x7 is 11lbs....and is dirt cheap.
Check out http://www.edgeracing.com
Old Nov 4, 2007 | 11:49 AM
200TS EC's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (problem_si)
Thanks!
That is exactley what Im looking for !!!
Old Nov 5, 2007 | 03:46 PM
Boricuanology's Avatar
Thanks </TD></TR></TABLE>
Good question, I was about to ask the same
Old Nov 5, 2007 | 08:47 PM
200TS EC's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (Boricuanology)
Old Nov 7, 2007 | 06:02 PM
Can the wheels mention here be use for drag racing, besides using them everyday?
Is there a website that will show your car and you can choose how your car will look with different wheels .
Old Nov 7, 2007 | 08:04 PM
burke420's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (jmai86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmai86 &raquo;</TD></TR><TR><TD CLASS="quote">Enkei RPF1's are probably the best bang for your buck outta that list </TD></TR></TABLE>
im with him, i orderd them after i found out the weight, price and did it! for $117 a wheel, you cant go wrong
Old Nov 8, 2007 | 10:00 AM
problem_si's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (burke420)
where did you find rpf-01's for $117 apiece?
Old Nov 8, 2007 | 09:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by problem_si &raquo;</TD></TR><TR><TD CLASS="quote">where did you find rpf-01's for $117 apiece?</TD></TR></TABLE>
X2, I will like to know also, in case I go with this rims, also are originals right? Not some imitations one. Sorry But todays days they can make a knock off of anything out there.
And once again, is there a site that let you see how you car will look with different type of rims, that way it will be easier to decide which rim you like the best.
Old Nov 9, 2007 | 03:58 AM
problem_si's Avatar
discounttiredirect.com has an interactive program that lets you "try on" wheels on your car. Unfortunately, they don't have every car, i.e. they don't have ef hatches
Old Nov 9, 2007 | 09:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by problem_si &raquo;</TD></TR><TR><TD CLASS="quote">discounttiredirect.com has an interactive program Unfortunately, they don't have ef hatches </TD></TR></TABLE>
WHATTTT!! Thats it, Im writing a letter!!!
Old Nov 9, 2007 | 12:18 PM
KaBlookie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by problem_si &raquo;</TD></TR><TR><TD CLASS="quote">Falken hannabi in 15x7 is 11lbs....and is dirt cheap.
Check out http://www.edgeracing.com</TD></TR></TABLE>
AMEN. I have a set of those wheels, and if you're looking for a cheap, lightweight wheel, there is NOTHING that costs close to what these cost that weigh as little as these.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boricuanology &raquo;</TD></TR><TR><TD CLASS="quote">Can the wheels mention here be use for drag racing, besides using them everyday?
I've had mine for a little over 2 years and over 20k miles and they're still perfect...I hit a huge pothole that dented my stock header pretty bad and dented the oil pan, and there was absolutely no damage to the wheels at all. I've gone through a lot with these things...in this size with normal sidewall tires (195/55 or 205/50) they'll put up with a lot of abuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleshotz &raquo;</TD></TR><TR><TD CLASS="quote">listed by price (high to low)
All amazing wheels...the Falkens should definitely be added there as a possibility.
Falken Hanabi = 11lbs (15x7)
...and they're noticeably cheaper than even the Slipstreams.
Old Nov 11, 2007 | 03:26 AM
problem_si's Avatar
Again...where did you find rpf-01's for $117 apiece????
Edgeracing.com has them for $199-$203 apiece, and they're the cheapest I've seen around.
Old Nov 12, 2007 | 05:58 AM
civic2sick's Avatar
I'm surprised no one mentioned Konig Heliums! These I believe are rated as one of the lightest wheels. I've been using these for about a year now through pot holes, and all sorts of rough roads with no issues. The wheels are very affordable as well.
Here's a link, although I'm sure you could find them even cheaper.
http://www.1010tires.com/wheel...ronze
Old Nov 12, 2007 | 05:03 PM
h22 civic's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (civic2sick)
racing hart cp-035 the lighteset rim you will find
Old Nov 12, 2007 | 07:31 PM
DunkJDM's Avatar
konig heliums and feathers are really light
Old Nov 13, 2007 | 08:12 PM
KaBlookie's Avatar
Default Re: Lightest 15 inch Rims for Everyday Use (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">racing hart cp-035 the lighteset rim you will find </TD></TR></TABLE>
Yeah, but only if you get them in lame 15x6 size...if you're looking at 15x7s, the Volk TE-37s are the lightest at 9.15lbs each.
Old Nov 14, 2007 | 03:53 AM
Mike_C's Avatar
Default Re: (Boricuanology)
1. they're round, why not?
2. tire rack has one
Old Nov 14, 2007 | 08:59 AM
HipHapa-Eg's Avatar
From: Where friends and family is all that matters, CA
the RPf1's are a good choice
but buddy club sf or qf are some nice light wheels that are affordable
Rob.
Jul 31, 2006 08:19 AM
pythoner
Jan 14, 2006 12:45 PM
SixguN
Feb 3, 2005 08:46 PM
madman13lm
27
May 6, 2003 11:58 PM
X2BOARD
Oct 3, 2001 08:17 AM
