burned valves
Old Nov 2, 2007 | 01:29 PM
njracer's Avatar
Default burned valves
Is there any simple remedy I can do for burned valves. Can I try to do a valve adjstment, or is it time for rebuild.
Old Nov 2, 2007 | 02:36 PM
si_motor_spt's Avatar
Default Re: burned valves (njracer)
i guess rebuild... once the valves are out, u can use a wire wheel machine and clean up the valves pretty nice and then grind the valves down(with a valve grinding machine of course) should look nice or at lease give a picture of wat is going on....
junkyard racer
Sep 7, 2008 04:41 PM
str8JDMteggy
Nov 10, 2006 02:03 PM
VTECcnIT
Nov 9, 2005 05:43 AM
