can u drive the car if the tie rod is loose but tha bolt is still in ?
Old Nov 2, 2007 | 11:28 AM
MesicanRSX04's Avatar
Default can u drive the car if the tie rod is loose but tha bolt is still in ?
because the tie rod that is connected to the suspension is in and the bolt is to but only a little and wont keep turning to go up would i be able to drive it just so i can get to a shop?
Old Nov 2, 2007 | 11:58 AM
skivik's Avatar
Default Re: can u drive the car if the tie rod is loose but tha bolt is still in ? (MesicanRSX04)
sounds kinda sketchy to me.... why take a chance of destroying your car just get it towed
Old Nov 3, 2007 | 12:12 AM
mark31kiss's Avatar
did you get hit or did you just put a new tir rod.... how would that get loose
Old Nov 3, 2007 | 12:14 AM
Default Re: can u drive the car if the tie rod is loose but tha bolt is still in ? (mark31kiss)
its because i put new springs into my car and i could only get the bolt that holds the strut and the tie rod to go up a little then it wouldnt but i took it to a shop cuz i was tired of dealing with it.........but after they installed the springs there is like a popping sound when i turn on the driver side only does anyone know why its doing that?
Old Nov 3, 2007 | 12:23 AM
mark31kiss's Avatar
mine does that to... right after i put on my springs. but i never did anything with the tie rod but yeah its safe to dirve to a shop but i would just tighten the tie rod bolt as much as you can i just installed the driver side tie rod with ease.. but thats all i can say
Old Nov 3, 2007 | 05:49 AM
risktypeS's Avatar
need to get an alignment after messing with the tie rod and installing new springs.
Old Nov 3, 2007 | 06:56 AM
WhiteOnRice's Avatar
Based on your previous thread, I think it's your axle. When you had to slide the joint back in, did you ever take the boot off? ANY dirt in there and it's shot.
Old Nov 3, 2007 | 09:43 AM
Default Re: (WhiteOnRice)
no i never took the boot off i drove it to the shop how i had it and didnt make noise but after the shop installed my driver side spring it keeps making like a crunching kind of noise when i turn left and it only on the driver side
Old Nov 3, 2007 | 12:45 PM
DR DC5's Avatar
Default Re: (MesicanRSX04)
do you hear popping/crunching noises after upshifting through the first few gears?
Old Nov 3, 2007 | 12:55 PM
DR DC5's Avatar
...the bearings on your axle are prolly shaved off. u might have to get a new one. have the shop look @ your axle to make sure.
Old Nov 3, 2007 | 03:49 PM
phthalo's Avatar
GDD4LIFE
Default Re: (tekniqueDC5)
my car made popping noises too. It went away after a while after everything settled in. how much did you drop your car? also if the nut wouldn't tighten anymore you could've just held the bolt with some small vice grips and tightened it that way.
Old Nov 3, 2007 | 05:17 PM
no its nothing with the gears its just the spring maybe cuz their new? well i hope they go away soon cuz it sounds pretty shitty and i lowered the front 1.4"
Old Nov 3, 2007 | 05:26 PM
I still say axle
Old Nov 3, 2007 | 11:47 PM
NTCustoms's Avatar
mine pops because my left tie rod boot is bust.
Old Nov 4, 2007 | 06:05 AM
Default Re: (NTCustoms)
so im gonna have to get a new tie rod boot ? cuz i dnt think its the axle cuz the noise comes from up top where the springs are at not any where else
Old Nov 4, 2007 | 08:04 AM
NTCustoms's Avatar
also check how the spring sits. and no, if your tie rod boot is bust, you'll need a new tie rod. by bust i mean you popping the actual boot or puncturing it.
Old Nov 4, 2007 | 09:10 PM
ohh well no its not punctured and the tie rods are like this \_/ like they go up instead of straight is that common after altering the suspension and i think that popping sound comes from the tie rod hitting against something thats around it because its close to somethings around it on both sides but it only makes noise on the driver side
Milab21
Suspension & Brakes
Dec 10, 2009 11:22 AM
LOC714
Nov 14, 2009 11:30 PM
KHowe
May 1, 2007 08:32 PM
Groove_D
Nov 13, 2005 11:36 AM
RCautoworks
Jun 28, 2004 07:10 AM
