Power Steering Pump on H23a1 compatiable with h22a?
Old Nov 2, 2007 | 10:18 AM
Acidcrakker's Avatar
Default Power Steering Pump on H23a1 compatiable with h22a?
Yep just like it says in the title. Im doing a dry run of engine removale today. Hopefully removing whole thing tommorrow.
Old Nov 2, 2007 | 10:29 AM
Hawkze_2.3's Avatar
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (Acidcrakker)
Check the part #s: http://www.hondaautomotiveparts.com
Old Nov 2, 2007 | 10:33 AM
94Vtecluder's Avatar
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (Hawkze_2.3)
You should be okay.
Old Nov 2, 2007 | 10:40 AM
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (94Vtecluder)
Im also looking at the ac. I dont think it will go one with out changing the pulley to 5 ribs. So mabey no AC. unless I can get that. Same for power steering. This is going to be fun. Its gonna take me around a day to get it out, and probally 3 days gettting extra parts. and one more day to drop it.
Old Nov 2, 2007 | 11:09 AM
SikB's Avatar
To answer the question in your topic. Most likely not! When I did my swap the power steering pump on my h23 not bolt up to the h22 bracket. Additionally the h23 bracket will not bolt up to the h22 head. Furthermore the jdm ps pump that came with the swap has a different outlet connector. I say most likely because I don't know what year they used which pump nor do I know exactly what you have or what you are buying. But if it doesn't bolt up you might as well take the pump out while the engine is out and loop the lines because I have not been able to find a working bracket anywhere.
Old Nov 2, 2007 | 11:16 AM
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (SikB)
So your saying drive around without power stearing?
Old Nov 2, 2007 | 12:13 PM
4thgenner's Avatar
i do
Old Nov 2, 2007 | 12:15 PM
Default Re: (4thgenner)
Do you daily drive?
Old Nov 2, 2007 | 03:14 PM
4thgenner's Avatar
ya. when it runs lol. it is a bitch, but doable. low speeds suck though.
all i did was pull my belt though. since the pump is fried/leaking. if i loop my lines, it would be a lot easier.
Old Nov 2, 2007 | 03:19 PM
The bracket is different, but the part numbers for the pump seem to be the same to me no?
112546 003 1 PUMP SUB-ASSY., POWER STEERING SI
112546 003 1 PUMP SUB-ASSY., POWER STEERING VTEC
But yes the bracket is different.
Old Nov 2, 2007 | 03:21 PM
Default Re: (94Vtecluder)
Whats the bracket?
Old Nov 2, 2007 | 03:26 PM
SikB's Avatar
I put a JDM OBD1 H22A into an OBD 2 SI. That is why I basically said his experiences may differ since I don't know exactly what he has. Yes I drive without ps. The funny thing is it turns more difficult at ultra low speeds but turns easier at high speeds. As long as you don't try to turn the wheel while sitting still you won't have any problems and barely notice it. If you look around the board a lot of ludes run without it.
I must say that not every car is like this though. I drove a lumina with a broken pump that wouldn't hold fluid and I thought I was going to break my arms on that pos.
Default Re: (Acidcrakker)
According to majectic honda they are the same. Both labeled part number 16 on the following pages
H23
h22
Old Nov 2, 2007 | 03:27 PM
112550 011 1 BRACKET, P.S. PUMP SI
112551 011 1 BRACKET, P.S. PUMP VTEC
Number 11
Old Nov 2, 2007 | 03:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">According to majectic honda they are the same. Both labeled part number 16 on the following pages
H23
h22</TD></TR></TABLE>
rebump
let me know if this is wrong. The h23 one is off the 92, 2dr si, ka5mt
The h22 is off the 93,2dr si vtec, ka5mt
Old Nov 2, 2007 | 06:09 PM
boostedh22lude1's Avatar
u can use the h23 belts on the h22 pulleys, it will just have less ribs, the pumps are the same
Old Nov 2, 2007 | 07:34 PM
dagle's Avatar
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (boostedh22lude1)
driving without p/s isn't that bad at all if you keep your tires inflated properly. When I first got the car w/ the 20% tread + at like 25PSI, the contact patch was huge so it was very hard to steer at low speeds. now that im on brand new tires w/ proper inflation, i can turn/steer normally with 1hand (other hand on shifter) but before i would have to rip at it..
as for the pump, im pretty sure they're not the same, but if you order it and it works, let use know.
Old Nov 2, 2007 | 09:03 PM
ismkv8s's Avatar
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (dagle)
Total bs the h23 bracket and pump work I have it on my h23 vtec, you just have to cut a tab that sticks in the the h23 and there is no prevision for that on the h22 head.
Old Apr 26, 2008 | 06:26 AM
brad225's Avatar
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (ismkv8s)
i have the same prob with my power steering will not mount to my h22 had an h23 the pumps are not the same if they were i would have p s i am working on trying to make a brakett right now
Old Apr 26, 2008 | 11:08 AM
Default Re: Power Steering Pump on H23a1 compatiable with h22a? (brad225)
You have to use the h23 braket and h23 PS Pump.
On the H23 braket there is a part where it just does not physically bolt to the head. You have to grind that part physically off. Angle griner, I used and its fine.
frstbte14
Jun 7, 2007 08:40 AM
outlawstar27
Apr 26, 2007 11:14 PM
WillsH22Accord
Nov 12, 2004 01:58 PM
stubk20
May 26, 2004 07:01 PM
