***Help*** Accord Won't Start (Fuel)
Old Nov 2, 2007 | 04:59 AM
raymondlee's Avatar
Default ***Help*** 95 Accord lx Won't Start (Fuel)
I am fairly new to this so bare with me.
1995 Accord Lx
186,xxx miles
Auto
Ok first off all the car had a starting problem and it was overheating
Replaced radiator, thermostat, Distibutor cap, Main Relay and some lil Temp sensor, and it was fine for a while(as far as overheating) Still had the starting problem where its bucks and tries to start but just won't until like an hour later an only if i gave it gas while cranking, ok you still with me? once i would get it started it was over heating again. So I replaced the head gasket myself. Got everything put back together and the car won't start at all. It turns over but not start. main relay clicks, but i get no fuel to the fuel rail. i've seached and jumped the fuel pump and its fine. It there some ground or somethin that i could have messed up during reassmbly of the head.
So basically somethin's not telling my fuel pump to come on. Also i tried the to get codes fro mthe ecu but it doesn't throw any.
Any help would greatly be appreciated
Modified by raymondlee at 7:18 AM 11/2/2007
Old Jan 21, 2008 | 04:31 PM
kawgomoo's Avatar
Default Re: ***Help*** 95 Accord lx Won't Start (raymondlee)
ecu and ignition switch control the main relay. main relay controls the fuel pump. if the pump is not turning on, and the main relay is good it is possible ignition switch is bad.
more likely the dizzy is NFG or you forgot to plug something in when you had the head removed.
Old Jan 22, 2008 | 02:13 PM
NeKe1point0's Avatar
since the headgasket was recently replaced there is plenty that couldve gone wrong...
start with the basics
spark, fuel, and compression = combustion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raymondlee &raquo;</TD></TR><TR><TD CLASS="quote">but i get no fuel to the fuel rail.</TD></TR></TABLE>
turn key in "on" pos and have someone lean under rear of car and listen for fuel pump priming.
also, have you checked the plugs to verfy that there was no fuel ?? if not pull plugs to verfy the no fuel issue and while there out check for spark.
pullingin
Oct 28, 2016 02:56 AM
JMalek
Nov 9, 2011 10:04 AM
atapia2002
May 19, 2008 11:54 PM
9civic5
Oct 6, 2005 07:02 PM
gumbybum
Oct 9, 2002 11:22 AM
